SOURCE: VALSI 5,500 WATT GENERATOR WILL NOT START
All generators need to be run once a month. All things from the tank to the and including the carb will get gummed up with dried out fuel. I have a whole house generator and a 5500 watt gen set on my motor home. I keep fresh fuel in the stand alone house generator in California in case of a bad earthquake. I drain the gas after every run and keep all vehicles full of fuel just in case. Run gen sets at least once a month or pay pay pay!!
SOURCE: Honda gas power pressure washer runs for awhile then cuts off.
did you pour all of the old gas out before you started to use it. Sometimes condensation builds up in gas tank when stored. You need to dump old gas an put in new gas.
SOURCE: Karcher pressure washer with Honda GC160 engine only runs on chok
You need to remove the carb bowl, then with a small flat screwdriver remove the jet. ( on the side, at the bottom of stem.) take a small wire or toothpick and clean the gunk out of the jet, reassemble and open fuel valve, start, and pat yourself on your back.
SOURCE: pressure washer only works if
Hello..the unloader valve on the pump where you attach your water supply and your pressure outlet hose is the problem.There is a spring relief valve that is most likely frozen and not allowing the water pressure from the pump to circulate within itself.They range from 60.00 to 150.00 depending on your make and model.
SOURCE: honda powered gx160 model pressure washer wont start
Did you drain out the fuel before you stock it? If you didn't, you may need to clean the carburetor or replace a new one because the fuel inside has become a kind of stick varnish. You may take a look at following link to see how to change or replace a carburetor. http://solosmallengine.blogspot.com
