20 Most Recent Dewalt DPD3300 Commercial Pressure Washer Questions & Answers
Dewalt pressure washer losses pressure after running for a few minutes
What is your model #
6/11/2014 3:52:35 AM • Dewalt DPD3300... • Answered on Jun 11, 2014
My dewalt dpd3300 ,why is it getting gas in the oil
This happens when the gas needle valve in the carburator sticks open. With it open, gas continues to flow into the carburator then into the cylinder and finally down into the crankcase. It can be caused by dirt in the needle valve's seat, a stuck needle or float. Most of the time you can remove the float bowl and flush out any dirt. If there's a lot you should consider flushing the gas tank and check your gas can for dirt. If the washer has been sitting for a long time the problem could be varnish is gumming up the carb works. Carb cleaner works well to flush that out. If the float, needle or seat is damaged you'll have to rebuild or replace the carb.
1/23/2013 6:28:49 PM • Dewalt DPD3300... • Answered on Jan 23, 2013
Operating instructions
The Instruction Manual for the Dewalt DeWalt DPD3300 3300 PSI 28 GPM Commercial Pressure Washer can be downloaded from the following site:
http://servicenet.deltaportercable.com/Products/Detail?productNumber=DPD3000IC
Scroll down in the Downloads box to the desired item; select the icon under PRINT DOCS to open.
6/29/2011 2:47:59 AM • Dewalt DPD3300... • Answered on Jun 29, 2011
I would like to know if this pressure wahser use
If your engine has a place to put oil, then your power washer uses ordinary gasoline.
The only type engine that uses 2-cycle oil and gas mixture is engine that has no place to put oil.
Oil for pump comes half way up >>> pump uses SAE20 or SAE 30 non-detergent motor oil
Oil for engine comes half way up dip stick and uses 10-W30 motor oil
10/16/2010 3:27:40 AM • Dewalt DPD3300... • Answered on Oct 16, 2010
Engine does not start easily after shut off
if there is water pressure still hooked up then pump is primed and a sensor { that kicks the idle down when not pulling the trigger} is restricting the fuel flow. see if problem continues without pressure
5/3/2010 2:55:07 AM • Dewalt DPD3300... • Answered on May 03, 2010
2answers
Dewalt 3800 pressure washer got no fire to the spark plug
Try disconnecting the oil level switch.
10/11/2020 9:39:13 PM • Dewalt Garden • Answered on Oct 11, 2020
I bought a DeWalt DG6000E that is missing a Shutoff Solenoid on the carb. I can get a replacement but it has two wires on the bottom that I cannot find a place to plug them in. Can you help please.
The after fire solenoid helps prevent backfire when the engine is turned off. You can operate the genset without the solenoid and likely it will shut off without issue.
You can easily test by removing the solenoid plunger or the tip of the plunger and reinstall the solenoid.
10/22/2019 7:03:00 AM • Dewalt Garden • Answered on Oct 22, 2019
0answers
What is proper pump oil level
There should be a mark on the dipstick min and max. Keep within the 2 marks.
10/2/2017 7:54:28 PM • Dewalt Garden • Answered on Oct 02, 2017
My dewalt 3800 presher washer gas, is not getting any spark. 1) new spark plug 2) new spark plug wire I still do not get any spark. What could it be?
spark plug wire? do you mean coil? if you have no spark. i would check the plug first. then the coil assuming the on of switch is good. unplug the coil kill wire and try it. if it starts then you have a switch or wiring problem. if it don't start it is likely the coil is bad.
11/24/2016 7:18:57 PM • Dewalt Garden • Answered on Nov 24, 2016
Dewalt DPD3300 Commercial Pressure Washer Logo
11 questions posted
Top Dewalt Garden Experts
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you a Dewalt Garden Expert? Answer questions, earn points and help others
View Most Popular
Dewalt Garden
  • Dewalt Garden
Most Popular Question
dewalt dpd3300 getting gas in oil
  • Garden
