Coffee Makers & Espresso Machines Logo
Alice Nicolai Posted on Mar 17, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Han HS-20 will not expel steam is there any thing I can do to make it work
Stephen Miller
Level 3:
  • Coffee Maker... Master 1,645 Answers
  • Posted on Mar 17, 2019
Stephen Miller
Level 3:
Answers
1645
Questions
0
Helped
866252
Points
9471
Stopped expeling steam
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
1helpful
My CVA620 machine asks to "expel air " but
keep holding the hot water button down until you get a steady stream of water with no air. if you continue to get the error message after the water comes out, you will need to check the flow meter. if water never comes out, you have a leak inside the machine, a pump issue, or a blockage in the water path. That machine uses the same pump for steam and hot water, so if your steam is working, your pump is probably good. Blockages usually occur from not descaling properly. That machine is prone to leak at the hose fittings. the original o rings were black rubber, and failed fairly early. the replacements are red silicone and last much longer.
2answers
The seal on pressure cooker #99700 leaks after pressure builds up and a dangerous amount of steam is expelled . we were almost scaled by the steam.
>>> Please leave feedback so I can continue helping You & Others
make sure the pressure relief valve is working, not blocked etc, if it's OK try replacing the seal.
Thanks,
Adam.
Feb 19, 2011 • Vacuums
Will not expel steam but has steam built up inside. is my mop still under warrenty?mod.3550 ser. 120544
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
[[]][p[
5helpful
Window shows "Expel Air" message.
Fill the water tank.
- Turn the program selector to "On with
light" and place containers below the
hot water dispenser and the steam
nozzle.
- Press the hot water button, turn the
steam selector counterclockwise
and let water run out until it streams
steadily.
- Press the hot water button again.
Turn the steam selector to "o" to shut
off the water.
ENJOY YOUR COFFEE
Bissel pro heat cleaner won't expell water -- seems no suction
The reason that it won't expel water is because your pump belt is stretched and worn. You need to replace that belt, it is pretty easy. Here is the belt you need:
Bissell ProHeat Pump Belt
5helpful
My Miele CVA620 machine announces 'Expel Air,' and
I'm probably to late for this answer, but I will share it anyway.
I got this problem after buying a used CVA620, that had not been used for a while.
To solve the problem i used a breast pump :-)
My wife had this doublepump after the last kid. And I used the hoses that comes with this unit (rubber-like) and connecting them to the hot-water and the steam-nozzles. I started pumping, and pushed the hotwaterbutton. After 5min of pumping and swearing, the job was done. No my CVA works as a charm again :-)
Sanapathic
do you not have instruction book opration guide?? to make steam you req water then a method of heating it thus produce of steam results and pressure which expels via a nozzle ? just like the electri kettle
4helpful
13answers
Expel Air
Expel air is a common problem, but if the manual's method doesn't work, it can mean only one thing, the pump is not working. You should hear the pulsing of the pump while in expel air mode. If not the pump or its circuit is suspect. The parts are SAECO and available without paying Miele's ridiculous markups.
1helpful
3answers
Meile espresso maker does not expel air
Press Hot Water and Steam Button at same time.
Top Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
