b
bob donaldson-pirc Posted on Mar 11, 2019
How to change time zone - Audio Players & Recorders
I need central time set on my Alexa.
Did you try asking?
"Alexa, set to central time zone"
But basically, you just need the time changed unless you are asking time zone related questions. You realize Alexa is the woman inside the device like Siri is inside an iPhone. Device model details are useful in such questions.
How to change the time on your Amazon Echo speaker ...
The Ambient https://www.the-ambient.com > how-to > change-time-a...
1. Swipe down from the top. · 2. Tap the 'Settings' cog. · 3. Scroll down and choose 'Device Options'. · 4. Tap 'Date & Time'. · 5. Click 'Time Zone' and choose ...
Guide: How-to Change Time Zone on Amazon Echo
alexafaq.com https://alexafaq.com > guide-how-to-change-time-zon...
How-to Change Time Zone on Echo · 1. Launch the Alexa app on your iOS or Android device. · 2. Press the Menu icon on the top-left corner. · 3. Go to Settings. · 4.
How To Change Location And Time Zone On Alexa?
smarterve.com https://smarterve.com > how-to-change-location-and-ti...
Go to the "Settings." Click the "Devices" section. Search for the "Time Zone" option. Choose the desired correct time zone and save it. Videos
tip
Procedure For Setting Time Zones For Emerson Clock Radios
Setting The Time, The First Time
IMPORTANT: The first time you connect your new SmartSet® clock radio to
the AC outlet the internal computer will automatically set the time correctly for
the Eastern Time Zone, which is the initial default setting. The display will
scan for a few seconds and then show the correct Day and Time in the Eastern
zone. If you live in the Eastern Time zone, there’s nothing else to do. Your
clock is set correctly and running.
If you do not live in the Eastern Time zone you must change the default zone
display to your own zone. You only do this one time and the SmartSet® will remember
the new default zone setting and will always return to that setting after a power
interruption.
There are 7 time zones programmed into your SmartSet® clock radio as follows:
ZONE 1 — Atlantic Time
ZONE 2 — Eastern Time (Default Setting)
ZONE 3 — Central Time
ZONE 4 — Mountain Time
ZONE 5 — Pacific Time
ZONE 6 — Yukon Time
ZONE 7 — Hawaiian Time
To change the default time zone display, depress the Time Zone button.
The number “02” will appear on the display
indicating that the default zone is ZONE 2,
Eastern Time
Set clock on computer
  1. Press the Windows key on your keyboard to display the taskbar if it isn't visible.The Windows key has the Windows logo on it.
  2. Right-click the Date/Time display on the taskbar and then choose Adjust Date/Time from the shortcut menu.
    The Date and Time dialog box appears.
  3. Click the Change Date and Time button.
    The Date and Time Settings dialog box appears.
  4. Enter a new time in the Time field.
    You can also use the up and down arrows next to that field to change the time.
  5. If you wish, click on a new date in the calendar display and then click OK.
    You can also change the time zone, if necessary.
  6. Click the Change Time Zone button, choose another option from the Time Zone drop-down list, and click OK.
    If you don't want your computer to adjust for Daylight Saving Time, click Change Time Zone and click the Automatically Adjust Clock for Daylight Saving Time check box to turn this feature off.
  7. Click the Change Date and Time button.
  8. Enter a new time in the Time field.
  9. If you wish, click on a new date in the calendar display and then click OK.
  10. Click the Change Time Zone button, choose another option from the Time Zone drop-down list, and click OK.
How do i change time on my lenovo tab to pacific time
Go to settings, Time and Date, make sure that the time zone is not gray out, if it is, disable automatic time zone, scroll down to the time zone and change it to Pacific, which is GMT -08:00
2answers
How do you get rid of time zone New Zealand?
. You can change the clock's time and time zone.
  1. Open Date and Time by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, clicking Control Panel, clicking Clock, Language, and Region, and then clicking Date and Time.
  2. Click the Date and Time tab, and then click Change date and time. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. In the Date and Time Settings dialog box, do one or more of the following:
    • To change the hour, double-click the hour, and then click the arrows to increase or decrease the value.
    • To change the minutes, double-click the minutes, and then click the arrows to increase or decrease the value.
    • To change the seconds, double-click the seconds, and then click the arrows to increase or decrease the value.
  4. When you have finished changing the time settings, click OK.
  5. To change the time zone, click Change time zone.
  6. In the Time Zone Settings dialog box, click your current time zone in the drop-down list, and then click OK.
2answers
Setting time smartset
I couldn't figure out how to change the time zone because I didn't have the manual. Here's how to change time zone:
1. On top of clock you hold down time zone button
2. Push the up or down button to change the time zone. There are 7 time zones. The clock is set at zone 2 -Eastern Standard time. My zone is 3 -Central Time - I then had to manually set the correct time -(I'm not sure why but I did that) To test if the time zone worked properly I switched the time zones and the time on the clock adjusted automatically to the associated time for that area. I, of course, moved it back to zone 3 and the correct time for central time was displayed. I am waiting to see if the time properly adjust when time the DST changes. Also, for the manual: http://www.emersonradio.com/owner_manuals_list.php?ID=157
This is the manufacturers website (Emerson) for the EZ Set clock radio. Hope this helps.
56helpful
9answers
IPhone sync with Outlook Calendar - Appointment time put on iPhone 1 hr later.
This solution pertains only to the one hour time difference people notice upon syncing to MS outlook.
In iPhone, there are two areas where you have an option to change your time settings.
1. When you go to 'settings', then to 'general', you can set up time and date, and also 12-24 hour format. Please note that changing the time here DOES NOT correct the problem, despite iPhone displaying correct date, time and time zone. Many people in this thread have stated that the problem persisted despite them setting appropriate time zone.
2. When you go to 'settings', then to 'mail, contacts and calendars' row (NOT the 'General' row) - you get an option to change your time zone at the very bottom of all the choices. You will see that wrong time zone is selected here - likely cause of the problem. Correct this choice and the one hour discrepancy between appointments in outlook and iPhone disappears.
Additional problem solutions - in the solution No. 2, if you set 'Time Zome Support' to 'ON', then all your appointments in the calendar will be displayed in the time zone of your HOME address. In other words, for example, if you are a person in central time zone, your appointments will be displayed ALWAYS in central time zone format - they will NOT change automatically when you travel from central time zone to eastern time zone. On the other hand, if you set the time zone support to 'OFF', then all your outlook appointment display times will change and adjust according to any time zone you travel to - This is often an inconvenience since most of us would like to remember our appointments as they were made in our home time zone, regardless of what time zone we traveled to.
Please note that the above solution pertains to only display of appoint times in outlook - This solution does NOT relate to the time displayed by iPhone and how that displayed time adjusts when you travel to different time zone away from your home time zone. This second issue is addressed below -
You can get your iPhone to display the current time in two ways -
1. Either always show the time in your home time zone, regardless of where you are (i.e., a person from Texas central time zone can set up to see the time always in central time, even if he/she travels to another time zone). This display setup is good for people who always think of time in their home time zone and then do mental conversions to reach at the local time zone time.
2. On the other hand, you can get iPhone to do this for you and change displayed clock time automatically to the local time zone that you have traveled to, away from your home time zone. Please note that enabling this capability in iPhone has no bearing on how the appointments are displayed in MS outlook.
Go to 'Settings'. Go to 'General' tab. then click on 'date and time'. Pick the 'set automatically' option to 'ON'. Now, the iPhone will automatically adjust displayed time to show the current time in which ever time zone you travel to.
If you set the 'set automatically' option to 'OFF', then you can select your home time zone. Then, the iPhone will always display time in your home city time zone and will NOT change even if you travel to a different time zone.
So, in summary, there are two places you need to adjust the time zones in iPhone - to do two separate tasks, first task of displaying appointments always in your home time zone upon syncing with outlook thereby avoiding the one hour skip; Second task of getting iPhone to display either your home time zone clock, or getting it to adjust current time to reflect the time in new time zone you travel to.
Hope this helps.
 Grubhead
Grubhead
SmartAviator
SmartAviator
