We tried replacing the fuse last night. At first, there was nothing, but when my husband banged on the top, the control panel lit up. We pressed the button to start it, and the whole thing died. We repeated this a couple more times, but no luck, the microwave kept shorting out immediately. We replaced with a 15 amp fuse that matches the size of the original. Is there anything else we can try before giving up?
SOURCE: Sharp R-1450 Microwave Oven
The most common suspect here is a shorted high voltage capacitor, since you say it blew the fuse right after Start, but I would certainly suggest checking the door switches and door switch mounts first. Just be sure you installed the right fuse. It would be a The switch mounts seem to break at about this point in the life of these models. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://www3.sears.com (the three is correct)
SOURCE: Control Panel of Maytag Microwave CMV 1000B doesn't work
You have a failed
membrane keypad.
If you (or someone you
know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically
involved.
You can usually find
helpful exploded view diagrams and order parts by entering your full
model number here.
There
should also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very
helpful
when troubleshooting & testing.
If you would like to
have us do this repair for you, we do that for $39.95 plus part costs.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your
model number) for more information & help.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: Microwave oven shuts off after one minute
This
is a problem in one of the damper-related components, most likely the
switch, but it may also be the motor or the damper door.
The
damper is a door inside that opens or closes depending on cooking mode.
If the controller senses that the door is not in the right position, it
will shut down the cook cycle.
Sharp models stop after
59 seconds.
See the attached sample
photo for a typical damper assembly.
What is your model number? We may be able to point you to the full service manual too.
If a switch is all you
need, we offer a universal type for only $5 postpaid which you can
order here.
The best place to order
parts for this brand is Tritronics. Or you can call them toll-free at 866-779-5835. Their Web site re-opens tomorrow.
We're
thoughtful rating of our answer.
William E. Miller
[email protected]
SOURCE: Maytag MMV4205BA microwave buzz/grind when operating then no power
you may have some arching inside where your magnatron is located.If you open the door on the right middle part there is a silverplate on the wall .If it is burned you may need to replace magnatron.if you do not seee burn marks it may still be the magnatron hope.that would be the only possible thing that would make the noise other then the mtor plate out of place.
SOURCE: Microwave not working-Sharp 798 M,oven Grill ok
usually the power diode failed if not check the magnetron some time door switch you have to check most of the microwave not worth to hire some one fixed it.if you call some of repair company they will charge mag + cap+diode+ labor it 's total $500.if you don't want to fix you still have to pay for service call $72..you can buy the kitchen counter around $100
