I have a technics SA 400 reciever. All the lights work when turned on, but no sound is coming out.
If your technics SA 400 reciever turns on all the light but does not seem to produce any sound. Then you need to understand that there seem to be a problem with the unit.
The problem mainly if from the output of the receiver. Check to see if the cables are properly hooked up to the receiver. Then also check if the volume is not on the lowest. Then you try to test other cords on the device to know if the problem is not from the cords.
If it is confirmed that the problem is not from the cord, then it means the jack/port is faulty and need to be replaced.
Have the jack replaced or the ports on the receiver and it will work perfectly fine.
Hope this was helpful
Goodluck,
Elect_Comp
