Check your battery connections and/or batteries. It sounds like the radio is trying to perform the “power on” sequence, but doesn’t have enough power to actually power on. Use fresh from the package or other “known good” batteries, and clean the battery contacts with rubbing alcohol and a clean paper towel. If there is corrosion or other oxidation on the contacts, you may need to use an emery board and then the alcohol wipe. Beyond that, the radio is not really “user serviceable”. Is there any chance the malfunctioning radio was exposed to water?
SOURCE: motorola talkabout ta288 walkie takie
http://www.theusermanualsite.com/manuals/mfg/motorola/motorola_twoway_radio_product_list_4.html
You will find the manual here. The radio is part of the 280 series radios, so there is a general manual on all in that series.
SOURCE: I have a Motorola Talkabout T5710. I no longer
Perhaps the privacy code has been changed on one of the radios? If you have a manual follow the instructions for setting the codes and make sure they are the same on both radios.
SOURCE: Is Bell South walkie talkie compatiable with other
Some number their channels differently, but all FRS/GMRS radios operate in the same mode and will have at least some frequencies in common. Check the channel/frequency lists for both radios and you'll be able to talk to each other.
SOURCE: how to get a motorola talkabout t5720 walkie talky
Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Program the frequency, code and Qt filter (if any) to match one another. For simple operation set the code and Qt filter to off (zero).
Best regards.
SOURCE: I need a user's manual
Absolutely! Here's a user manual for several different types of walkie talkies, including yours:
http://lib.store.yahoo.net/lib/starbattery/T56XXusersguide.pdf
Hope this helps! :]
