20 Most Recent Motorola MJ270R Talkabout Two-Way Walkie Talkie Rechargeable Radio Set, 27 Miles Range Questions & Answers
Need Manuel for Motorola Mj270r walkie talkies
go motorola web site
9/8/2012 7:55:50 AM • Motorola MJ270R... • Answered on Sep 08, 2012
Programming Motorola XPR 3500e please?
https://www.google.com/search?q=motorola+xpr+3500e+programming
MOTOTRBO XPR 3000e Series
Motorola Solutions https://www.motorolasolutions.com > portable-radios > x... Integrated Wi-Fi; Over-the-air software updates; Bluetooth® audio; Enhanced audio quality; Channel lock (XPR 3500e only); Improved expandability ...
MOTOROLA XPR 3500e UHF PORTABLE RADIO
Wi-Com Solutions Inc. https://wicom.ca > product > motorola-xpr-3500e-uhf-p... MOTOROLA XPR 3500e UHF PORTABLE RADIO. $1,298.00. With this dynamic evolution of MOTOTRBO™ digital two-way radios, you're better connected, safer and more . ..Not sure is this is relevant
3/23/2024 5:46:16 AM • Motorola Radio... • Answered on Mar 23, 2024
I have a pair of Motorola MS350 radios. 1 works fine but one does not receive or transmit. I have both radios set up the same.
If your frequency and code are set the same, you have either a battery problem or a radio problem. For a quick battery test, swap the battery pack from the good radio into the one with the problem and see if the problem moves. Then you will know if it is simply the battery. If both settings are identical and the battery swap does not solve the problem, you have a defective radio.
2/12/2024 3:14:21 PM • Motorola Radio... • Answered on Feb 12, 2024
2answers
I need help to dismantle a motorola radius sp10 2 way radio
Remove the battery, slip a small screw driver into the slot at the bottom of the radio between the outer housing and the battery tray, gently pry up. If your radio has a pair of battery contacts on the exterior they will come up with the tray. Be gentle, and do not disturb the Mylar ribbon that runs down the back of the tray. Once the tray is removed, using a frame removal tool (shaped like a squared letter U) you slip the tool in the channels on either side of the radio where you removed the battery tray. Then slide the tool upward until it meets the two plastic ears. The tool will slip under the ears and using your tool you can push the component board out the top of the housing. If your radio has an 8-dip-switch private line board, you may want to watch you do not damage or dislodge it in the process.
2/12/2024 3:05:06 PM • Motorola Radio... • Answered on Feb 12, 2024
Can the Motorola factory replace the battery in the H730 headset?
It is possible to have the battery in your Motorola H730 headset replaced, but it would likely need to be done by a third-party repair service as the battery is not typically user-replaceable. Motorola does not offer an official repair service for the H730 headset, so you may need to find a third-party repair service that specializes in repairing Bluetooth headsets. Be aware that third-party repairs may void any remaining warranty on the device. You can also consider purchasing a new headset if you prefer not to have it repaired.
2/27/2023 5:03:32 AM • Motorola Radio... • Answered on Feb 27, 2023
2answers
I have two older Motorola Walkies Talkabout FR60 wont send or receive and a T5820 with the rubber broken off the antenna is is cost feasible to fix or not
I believe for the FR60 walkie-talkies, if they are not sending or receiving, the issue could be related to the antenna, battery, or internal components. You can try replacing the batteries and/or antennas to see if that resolves the issue. As for the T5820 walkie-talkie, if the rubber on the antenna is broken, it's likely that the antenna itself is also damaged. In this case, you can try replacing the antenna with a new one. Antennas are typically available for purchase online or at electronics stores. In terms of cost, repairing older walkie-talkies like these may not always be cost-effective. If the repairs are extensive or require replacement of major components, it may be more practical to purchase new walkie-talkies instead. Below are options of the options of walkie-talkies you can buy; ir?t=emerald014-20&language=en_us&l=li2&o=1&a=b071kjlcjv
2/24/2023 3:00:37 PM • Motorola Radio... • Answered on Feb 24, 2023
Motorola Talkabouts T5820 and FR60.
Question moved from Televisions. Yes of course. Well made and efficient sets. https://www.google.com/search?q=Motorola+Talkabouts+T5820+repair ..
2/24/2023 5:21:36 AM • Motorola Radio... • Answered on Feb 24, 2023
Anybody know how to reset a Motorola DP4800e radio to its factory settings?
Let me know if you find out lol. Glen
2/5/2023 12:55:13 AM • Motorola Radio... • Answered on Feb 05, 2023
Motorola sliver headset won't power on even when the green lights are solid
There are a few things you can try to troubleshoot this issue with your Motorola Silver headset not powering on:
  1. Make sure that the headset is fully charged by connecting it to the charger for at least 30 minutes.
  2. Check the battery contacts in the headset and charger to ensure that they are clean and free of debris.
  3. Try resetting the headset by holding down the power button for 15 seconds.
  4. Try a different charger or charging cable to see if that resolves the issue.
  5. Make sure that the headset is not in pairing mode.
  6. Check the headset manual for any information regarding troubleshoot, or if there are any specific instructions for turning on the headset.
If none of these steps resolve the issue, it may be a problem with the headset itself and you may need to contact Motorola for further assistance. Please note that the information provided is based on my knowledge cut-off date and it may not be current.
1/27/2023 9:16:15 PM • Motorola Radio... • Answered on Jan 27, 2023
Can you use the Motorola XPR 4550 as a police scanner?
The Motorola XPR 4550 is a two-way radio, not a scanner. Scanners are devices that can listen to a wide range of frequencies, whereas two-way radios are designed for communication between a limited number of specific devices on specific frequencies. However, you can use a scanner to listen to the frequency that the Motorola XPR 4550 is transmitting on.
1/22/2023 4:26:08 AM • Motorola Radio... • Answered on Jan 22, 2023
Motorola XTL5000. encoding is working but decoding is not. If you encode a different tone on another radio it still hears it.
El problema de decodificaci?n de la radio Motorola XTL5000 puede deberse a una configuraci?n incorrecta de la radio. Aseg?rate de que la radio est? configurada correctamente para la codificaci?n y decodificaci?n. Por ejemplo, aseg?rate de que los ajustes de codificaci?n sean los mismos tanto para la codificaci?n como para la decodificaci?n. Tambi?n debes asegurarte de que la radio est? configurada en la misma frecuencia de la otra radio. Si esto no soluciona el problema, prueba la antena para asegurarte de que est? funcionando correctamente. Si la antena est? bien, podr?as necesitar reemplazar la placa de circuito impreso (PCB) del receptor para solucionar el problema.
1/6/2023 1:56:52 AM • Motorola Radio... • Answered on Jan 06, 2023
2answers
Radio Communications - Can you replace the plastic sleeve covering of the Motorola RDM2070d antenna?
they are available on eBay for $6.00 you can look online there are several vendors. google Motorola RDM2070d antenna good luck
12/21/2022 10:34:16 PM • Motorola Radio... • Answered on Dec 21, 2022
Motorola RDM2070d walkies, One shows battery is fully charged, the other says the battery is low and makes the alarm sound of dying battery
Check your battery contacts. Clean with a pencil eraser. If this does not solve the problem described then your radio is in need of repair.
12/21/2022 10:05:59 PM • Motorola Radio... • Answered on Dec 21, 2022
Motorola T8500 Two Way Walkie Talkie Radio. How to reset Please.
Question edited for full 'make model (what is it)'. Question moved from Cell Phones to Motorola 2 Way Radio. Remove the batteries for 5 minutes. There is no factory reset, it is just a radio. https://www.motorolasolutions.com/content/dam/msi/docs/products/two-way-radios/consumer/user-guides/t8xxx-series/t8500-user-guide.pdf More here https://www.google.com/search?q=Motorola+T8500+factory+reset ..
8/10/2022 1:34:26 AM • Motorola Radio... • Answered on Aug 10, 2022
2answers
Service center in bangalore
You could try taking out the batteries and putting it in rice for a couple of days and see if that helps. I got one of my Motorola 2-way radios wet and after I dried it out everything seemed to work except the microphone; my suspicion is that the transducer needed to be replaced but I found that I could get used Motorola 2-way radios on eBay inexpensively enough that it made more sense to buy some of those than it did to try to repair the radio I got wet. If you think you might be prone to dropping your two-radios in the water in the future, Motorola makes some two-way radios that are waterproof.
5/14/2022 11:07:20 AM • Motorola Radio... • Answered on May 14, 2022
Motorola Roadster 2 Tz710 Bluetooth In-car Speakerphone. Cannot pair my my devices
Question edited for full 'make model (what it is). Question moved to Motorola.
How do I configure the Roadster 2™? - Motorola Support
https://motorola-global-portal-en-ca.custhelp.com > a_id Reset to factory default. Description: Restores the device back to the default settings. Caution: This action erases all pairing information stored in your ...
MOTOROLA ROADSTER™
https://www.motorola.com > Roadster_QSG PDF Reset to factory default. Caution: This action erases all pairing information stored in your car kit. • Voice prompts. • Caller ID. 108 pages
Try a reset on it. You can reset your system by deleting the vehicle profile from your phone and disabling Bluetooth on your phone. Your vehicle's phone profile needs to be deleted. If you have such an option, disable Bluetooth on your vehicle. You can now pair your phone and the vehicle infotainment system by enabling Bluetooth. Dec 5, 2021
How To Pair Motorola Bluetooth Tz710? - Nstec.com
https://www.nstec.com > how-to-pair-motorola-bluetooth-...
4/30/2022 1:04:39 AM • Motorola Radio... • Answered on Apr 30, 2022
Motorola Elite Sliver will not charge or connect red light keeps blinking
I have a Motorola elite sliver and know it won't turn on and it doesn't want to connect I want to know if I can fix it thanks
11/27/2021 7:47:07 PM • Motorola Radio... • Answered on Nov 27, 2021
Hai Lu Hong earbuds. How can I connect both earbuds to my Motorola G5?
Try the attached links you should be able to download the manual. https://www.motorola-support.com/uk-en/?page=device/motorola/moto-g5
10/25/2021 1:30:56 AM • Motorola Radio... • Answered on Oct 25, 2021
Motorola MJ270R Talkabout Two-Way Walkie Talkie Rechargeable Radio Set, 27 Miles Range Logo
1 questions posted
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Radio Communications
Most Popular Question
need manuel motorola mj270r walkie
  • Radio Communications
