If the monitor loses power then I would open the monitor up and look at the power board. That would be where the power cord plugs into the monitor
On the power board there are a number of capacitors. They store electricity. Look at the top of each capacitor and if any one of the tops is bulged they will let the power escape to the monitor won't start. The capacitors must be flat on top. Any variation from flat will cause power failure. I'm not a expert in electrical componets. The only experience you mite need is the ability to solder.
SOURCE: subtitles disappear below bottom of screen
Check to see, what format the television set that widescreen etc. this may be all that's wrong with your set. If the problem persists the vertical height needs to be adjusted. Most likely through the service menu, if units under warranty you can call Akai. For further structures.
SOURCE: Program a universal remote for the Dynex 32" 720p Flat Panel
Try using the codes listed for Orion products. Worked for me.
SOURCE: remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
