SOURCE: picture keeps rolling
do you have cable to the set or are you on rabbit ears if on ears adjust antenna for the strongest signal.
SOURCE: Rolling horizontal lines on 62" Mitsubishi
That problem is caused by failed Capacitors on the signal and FMT power boards. which is a very common problem for mitsubishi TVs. There are repair kits available for the V26 dlp which contain the capacitors and instructions on how to do the repair. Heres a link check under the repair kits category.
http://servicemanuals.vstore.ca/
SOURCE: how to switch to antenna usage without a remote
several answers:
1get the original remote control
2get a universal remote control and maybe you can get menu from there.
3get menu on front panel of the tv and search for the option.
4send the tv to autoprogram. Good luck!
