20 Most Recent
Mitsubishi VS-5075 50" Rear Projection Television Questions & Answers
The horizontal hold
If model number correct (the one posted here) set does not have a horizontal (rolls left to right) or a vertical (rolls top to bottom) control.Verify model and brand so I may offer some suggestions
Power will not turn on.
wrightthefir,
This model has some serious documented problems. Most are on the DM board but it could also involve the power supply and another board. The electrolytic capacitors dry out and short circuit causing the problems you have. Replacement is an option but it does not always work.
If you love your machine and want to save it the following link has kits which will allow you to replace the known bad capacitors and they supply good instruction sheets.
http://www.tvrepairworld.com/
Thanks for using FixYa and for the great rating.
hardrocko
The power won't turn on. I hear a
Howdy,
This TV is a 1995 model, I would consider replacement than repair. Sorry, but it will cost about $550 to repair. If I could tell you that it was this little part that only cost $2.00, I would, but these old TV'S it could be anything.
Good Luck, BIG IRISH.
TV turns off and green LED light stays on.
Since when this problem started.. Are you able to check it yourself..
otherwise take it to nearby repair shop for replacing the Fuse and check power Control & Supply board.
No picture-picture-
Try resoldering the vertical output IC. If you still need a service manual let me know and I will post a link where you can get one.Just post the model number of your set.
Set-up
the set should have it's own tuner hook cable to ant and then select ant from remote input
Mitsubishi VS-5075
Your standby power supplies are most likely at fault you should check the low voltage regulators and see if they are functioning they may be defective.
TV won't turn on.
you have to hold the menu and input both in together for 10 seconds to see if the self diagnosis feature will blink a 2 digit code, indicating the cause of the shutdown
COLORES
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
la buena suerte marca por favor el poste con un fixya
Pip
ok nimrod they have many types of settings about pip viewer,will you please give the brand and model?
Pip only on screen
Try hard reset first==Unplug ac cord overnight,
then try again.Possible signal board trouble--
Practice visual acuity technique==look for CRT
coolant leak on circuit board.
Also suspect PIP PCB==can be by-passed by a knowledgible tech.
Please help
If its a rear projection TV. It sounds like the Lamp is shot on the projector, or is going. Look in the back and see if it is lit if it is flickering I would definitely suggest replacing it. If that doesnt repair it then I would ultimately suggest the optical engine which is the projector of the TV
Mitsubishi VCR HS-U580 guide rollers not moving forward all the way. Cassette would not load. Also noticed drum not spinning when powered on
Your Mitsubishi VCR HS-U580 looks to have a problem with the information rollers and drum. Here are some things to check:
Look for something blocking the VCR or cassette compartment that would possibly be stopping the guide rollers.
Check the belt that drives the VCR mechanism. If it is loose or broken, you may also need to substitute it.
Clean the video heads using a head-cleaning cassette to make certain they're not dirty.
See if the drum motor is working. If it is not spinning, there may be an issue with the motor.
If the trouble persists, it's an exact idea to get assistance from a professional technician or contact Mitsubishi's purchaser support for advice.
Be cautious when dealing with electronic devices, and if you are not certain what to do, it's great to get assistance from an expert.
