Try this site.
I FOUND THIS WEB SITE that I think will help you with this question and a lot more. Since this web site will have access to many different vehicles I hope you do not feel like I am lazy by just passing along the web site instead of giving you the exact information you asked for.
Go to this site to find a manual to help you.
https://www.browsemanuals.co/lander_zrk65_test14.html?t1=1535071160&t2=65192170713&t3=kwd-28425796&gclid=EAIaIQobChMI-oybpN624AIVwdVkCh2GtguWEAEYASAAEgJ9yvD_BwE
SOURCE: Sharper image ionic breeze air cleaner
I took the PCB below the power button off and removed the little metal triangles under the tape. I then cleaned the contacts (I just used a screwdriver but a more careful person might use a brush or something) and replaced the metal triangles under the tape (make sure it's concave down), and then replaced the PCB.
This fixed the problem for me. In general, look for corroded contacts.
SOURCE: I cleaned my air cleaner and now it will not turn back on
When you cleaned your cleaner, you must be gentle with it. Wipe down with a lightly moist cloth or paper towel. make sure you dont shove any grime between the metal cleaning grid and the plastic holding it all together. that can cause lots of problems. Your air purifier probably wont start because of an auto shut off safety feature. Be sure that everything is in its proper place.... make sure hte front grill is fastened on correctly as well as the back grill. if those are not secured properly the unit will not start. also, check that your collection grid is placed all the way inside the unit and wait for the click noise that indicates that its locked in place. at that point the unit should turn on and you can once again enjoy fresh, pure air!
SOURCE: Need Blubs for the Ionic Breeze GP
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-priority:99;
mso-style-qformat:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:11.0pt;
font-family:"Calibri","sans-serif";
mso-ascii-font-family:Calibri;
mso-ascii-theme-font:minor-latin;
mso-fareast-font-family:"Times New Roman";
mso-fareast-theme-font:minor-fareast;
mso-hansi-font-family:Calibri;
mso-hansi-theme-font:minor-latin;}
You can purchase a bulb for the GP on ebay for under $11, which is really a
good price considering what you would have paid from Sharper Image.
Installation is easy, you just pull up on the tab on the bottom of the filter
and pull up. When you are looking at the bulb, turn it 1/4 turn, (2
clicks) and pull it out. That is all there is to it. Item Number: 220444965077
SOURCE: sharper image ionic cleaner wire problem
these things are junk. you could also be doing more harm than good to yourself and the indoor air quality in your home with the amount of ozone these appliances omit into the air. throw it away
