20 Most Recent Sharper Image Ionic Breeze GP SI730 Air Purifier Questions & Answers
4answers
Ionic breeze is arcing inside unit
I have a sharper image ionic breeze hybrid gp that ran fine for years unitl it recently started sparking / arcing at the base of the grid blades and always in the same spot. I cleaned it several times but the sparking always came back and the unit went into either "drying grid" or "attention required" mode. The solution I found was to stand the removable grid in 2 inches of Pine-Sol cleaner 50/50 diluted with water for 24 hours then brush again with the cleaning brush and hot water. Presto! No more sparking.
5/16/2021 5:50:43 PM • Sharper Image... • Answered on May 16, 2021
2answers
Who repairs the sharper image ionic breeze GP
This is a repair that someone I know didafter reading a post on the net.....regarding Quadra repairs....and here is a link for repairs....its all one link....so type it into your browser or paste it.....
http://www.airpurifierrepair.com/ProductDetails.aspx?ID=34&ProductId=591
Remove the grid assembly.
Remove the 4 screws holding the top on.
Gently remove the top as there are wires connected to it.
Once removed, find the microswitch assembly on the side. There will be 2 green wires going to this assy board (PCB).
Examine the bottom of this board. On both my units, the PCB wascorroded badly on the trace that runs from the center lead to the wireconnection. This will cause the microswitch to quit working.
What I did was soldered a wire from the center contact of themicroswitch (center piece coming through the board. There should be alarge solder pool) to the wire connection at the edge of the board.This just 'goes around' the corroded PCB trace.
Worked fantastic on both ionic breezes and took about 5 minutes for thesecond one. The first one took over 2 hours just to find the problem.
I hope this helps.....good luck...thanks for rating my effort....the Fang.
7/14/2019 4:57:40 AM • Sharper Image... • Answered on Jul 14, 2019
No power is getting to model s1730 sharper image ionic breeze after taking it apart to replace light bulb. Is there a fuse in this model?
yes there is a fuse on the board located at the base of the unit...if that does not fix problem replace unit.. :) I’m happy to help further over the phone at https://www.6ya.com/expert/jovani_c02b023fe087f6cd
11/16/2015 4:45:11 AM • Sharper Image... • Answered on Nov 16, 2015
What does it mean when the cleaning light turns red?
It means that the unit needs to be cleaned.
8/7/2014 2:53:40 PM • Sharper Image... • Answered on Aug 07, 2014
What does it mean when the cleaning light is red?
It means that the corona wires require cleaning in order for the ionic filtration to again begin working (it is not filtering when the light is on).
7/9/2014 9:04:41 PM • Sharper Image... • Answered on Jul 09, 2014
I have model S1730, is
I have replaced those wires with chrome plated wire, stainless steel wires and platinum wires. Nothing lasts very long (weeks to a few months). There are no parts available for these machines as far as I know.
Charlie
6/15/2014 3:54:38 AM • Sharper Image... • Answered on Jun 15, 2014
Why does a red light on top of the ionic breeze GP S1750 blinks and does not blow the air
well i had the same problem at one time ..heres what to do... try turning it upside down and bang on the unit gently .not to break it and make sure you did not break the two strings behind the vents.. take out the bulb and clean the whole inside as best as you can.. and if that wont work unplug turn button to on pisitioin and then plug the unit inand hope for the best ... if all else fails go to amazon and replace the unit..hope that helps I’m happy to help further over the phone at https://www.6ya.com/expert/jovani_c02b023fe087f6cd
6/11/2014 4:17:18 PM • Sharper Image... • Answered on Jun 11, 2014
Operating manual
You can go right to the Sharper Image site and get manuals there. Just find your model, and towards the bottom of the description you'll find links to the manuals, Try this one http://www.sharperimage.com/pdf/Electrostatic-Air-Purifierc.pdf
4/20/2014 5:00:16 PM • Sharper Image... • Answered on Apr 20, 2014
0answers
S1730
Be the first to answer 4/10/2014 3:46:11 AM • Sharper Image... • Posted on Apr 10, 2014Be the first to answer
0answers
Sharper Image Ionic Breeze GP SI730 Air Purifier Logo
148 questions posted
Top Sharper Image Air Purifiers Experts
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
View Most Popular
  • Sharper Image Air Purifiers
Most Popular Question
broken wire inside ionic breeze
  • Air Purifiers
