Cars & Trucks Logo
R
ROBERT HANSEL Posted on Feb 22, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How much oil for ford1991 in qt. for transmission
Here2HelpYou
Level 3:
Master:
  • Ford Master 592 Answers
  • Posted on Feb 28, 2019
Here2HelpYou
Ford Master
Level 3:
Master:
Answers
592
Questions
0
Helped
152867
Points
4122
What model is your 91 Ford? Which engine does it have and is it an automatic or manual transmission?
2answers
Transmission fluid capacity for 2008 Lincoln Navigator
Need more help? Talk to me directly.
http://6ya.com/repairsolutions
Engine lubricant oil capacity: 6.6 liter / 7 U.S. qt / 5.8 imp. qt Engine coolant capacity: 21.9 liter / 23.2 U.S. qt / 19.3 imp. qt Fuel tank capacity: 106 liter / 28 U.S. gal / 23.3 imp. gal
2answers
I changed my oil in a 2006 mustang, auto transmission, and refiled with 8 qt transmission fluid. oil started dripping out of the front bell housing.. what could be wrong?
Check to see if it is transmission oil or engine oil. If engine oil then the crankshaft oil seal needs to be replaced. If it is transmission oil, your torque converter maybe leaking. Before doing anything major try checking the hoses that connects from the transmission to the radiator. They could cracked or leaking. Some transmission use oil coolers and ATF filer on the transmission case itself. Check if they aree properly tightened.
I would like to know the coolant capacity on a 1996 bmw 318ti
Engine lubricant oil capacity: 4 liter / 4.2 U.S. qt / 3.5 imp. qt with filter change Engine coolant capacity: 6.5 liter / 6.9 U.S. qt / 5.7 imp. qt Fuel tank capacity: 65 liter / 17.2 U.S. gal / 14.3 imp. gal Transmission oil capacity: 1 liter / 1.1 U.S. qt / .9 imp. qt Final drive oil capacity: 1.1 liter / 1.2 U.S. qt / 1 imp. qt Battery capacity (Ah): 50 Spark plugs: Bosch F7LDCR, NGK BKR6EK
2helpful
3answers
How much quarts does a 99 hyundai accent take?
Hi, your 1999 Hyundai Accent will need about 3.5 - 4 quarts of 5w30 Motor oil.
1helpful
What is the capacity(volum)of transmission and engin oil in denali 2007?
{: ) Engine Oil with Filter - All Engines 5.7 L (6.0 qt)
Transmission fluid:
4L60-E/4L65-E/4L70-E Pan Removal (4.7L), 4L80-E/4L85-E Pan Removal (7.3L),
6L50/6L80/6L90 Pan Removal (5.7L)
What is the oil capacity of an2002 xterra - 4 cyl?
Oil Capacity (Approximate)
DRAIN AND REFILL
With Oil Filter 3.5 l (3 3/4 US.qt, 3 3/8 Imp.qt)
Without Oil Filter 3.3 l (3 1/2 US.qt, 2 7/8 Imp.qt)
DRY ENGINE (engine overhaul) 4.1 l (4 3/8 US.qt, 3 5/8 Imp.qt)
How many quarts does trasmission hold
Hello skippy48067: My name is Roger and I will help you. You did not say if you have a automatic transmission of a standard so here are the specs on both. For the automatic the fluid type is (atf sp 111) and holds 6.2 qt. For the standard transmission the fluid type is (gl4 or gl5 80-90) and it holds 2.96 qt. If you have the standard transmission ? Be sure you use the correct fluid. If you do not use the correct type of 80-90 weight oil you will ruin the transmission. Should you need further help please just ask. Thank You for using Fix Ya. Roger
2helpful
2answers
2.2 4cl what wt. oil----is there anything to quiet lifters---140,000 miles---my friend said 1/4 qt transmission fluid
Transmission fluid will clean out the engine but then I suggest using 3 quarts of 5w/30 and 1 quart of 20w/50 at your next oil change.
2helpful
I use 2 qt oil in 3000 miles in my 2006 envoy is
No it is not normal to lose two quarts,Have you seen any oil spots on the ground where you park your Envoy,
take a look under your Envoy to see if you have a small leak and the air from driving it is blowing the oil back towards transmission.
2helpful
1 Solution for ''how much need oil automatic transmission honda cr v 2003 and whats type''
Honda recommends Honda ATF-Z1 Transmission Fluid or a Dexron III ATF as a temporary replacement -- which should be flushed from the system and replaced with the Honda ATF-Z1.
Change;
2WD model -- 3.1 US QT or 2.9 L.
4WD model -- 3.3 US QT or 3.1 L.
Total;
2WD model -- 6.9 US QT or 6.5 L.
4WD model -- 7.6 US QT or 7.2 L.
bikerbc
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
