SOURCE: Gas tank decal
Okay, I did this with my original tank. Your decals were most likely clear coated over after they were applied (at least mine were). To remove mine I wet-sanded carefully around the perimeter of the decal (to break the clear coat). Then carefully warm them with a hairdryer and peel away (long arduous process). They will likely leave a gummy residue that will need to be removed with something like “Goo Gone” or light solvent. Then some more wet-sanding to feather the edges. You’ll need to re-clear coat the spot and buff everything so it blends together.
SOURCE: COOKER DECALS DISSAPPEARED ON FRONT OF OUR 6 BURNER DELONGHI
Use a computer programme to generate the correct legend then print it on projector film or self adhesive transparent label and stick it over the original part..
SOURCE: we need a diagram to replece the serpentine belt
easiest solution,go to local car lot find same year and model,open hood copy diagram,or wrecking yard if old enough,or local parts house may have diagram in manual.
SOURCE: Ariston FM22 Oven No Control decals
Go to this site www.appliancepartspros.com and look up your model there and you can order the decals or replacement knobs there.
SOURCE: I need a Radio Flyer 90 decal
decals can be found at bluediamondclassics.com, also from radio Flier in Chicago IL. all their products lifetime warrenties
