SOURCE: nikon coolpix 7900 service repair manual
You can get it here:
http://www.justmanuals.com/nikon-coolpix-digital-camera-7900-parts-service-p-22630.html
But its not free.
SOURCE: Nikon Coolpix L4 flash not working
This has happened to mine a couple of times. I cannot select flash, and the blur indicator is on most of the time.
Solution is to go into 'menu', select 'SET UP' then 'reset all'. My flash selection then works again.
Since one doesn't tend to set much up with a basic camera like this, resetting shouldn't cause any issues.
Hope this helps
SOURCE: my nikon coolpix s230 wont let me use the flash
u have to change the battery by using 2100 mh ur broblem will resolved
SOURCE: My Nikon COOLPIX S51 Will not turn on.
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
SOURCE: my nikon coolpix s230 wont flash, is there anyway
Have you accidentally turned it off? Is there a picture of a lightning bolt with a line through it on the screen?
