20 Most Recent Nikon COOLPIX L101 Digital Camera Questions & Answers
That's not all that was damaged. Salt water is very corrosive and is still eating at the other parts of your camera not to mention getting in between the lens elements.
Nikon COOLPIX... | Answered on Jan 07, 2011
You don't mention the rating of your rechargeables- this can vary a lot. Some have twice the puff of others. The rating is not always prominently marked, but should be on the battery somewhere.
NiMH batteries with a capacity of 2700mAH or more are available, and these will obviously last longer per charge than those rated 1600mAH or so. However, all things come to an end, and while Ni-MH cells are supposed to be rechargeable hundreds of times under ideal conditions, in real life they will lose a bit of capacity every time until they become a bit short of puff.
Nikon COOLPIX... | Answered on Nov 30, 2010
Not sure exactly what the issue is here - could you be more specific please ? Thank you.
Nikon COOLPIX... | Answered on Feb 20, 2019
I would suggest you go to the Nikon support site and see if there is a version you can download from there.
Hi
Here are some suggestions to try and see where the problem may be:
1. Have you tried to charge the battery? We would suggest trying different USB sources (e.g. a USB port on a computer as well as the Nikon supplied AC adapter)
2. Could the battery be dead? If you have tried to charge the battery in the camera via USB then there is a chance the battery is dead and needs replacing. If the camera had not been used for a long time and the battery was stored with little or no charge, the battery may now be un-chargeable.
3. If the camera has been left unused for a long time the internal battery that keeps the time/date may have discharged. You need to be able to set the time/date before the battery can be charged. If you plug the camera into a USB power source and you can see the menu on the LCD then set the date/time.
We hope these suggestions help to get the camera back up and running
Nikon COOLPIX... | Answered on Jan 24, 2019
You have two main choices. Yes, you could buy a new memory card. But I find the extra small cards can be easily lost or misplaced.
A better method is to transfer the images from the camera to a computer or laptop. It is also possible to transfer the photos through the computer or laptop onto an external hard drive with a much larger memory as a back up. Then you can re-use the card you already have.
Nikon COOLPIX... | Answered on Jan 12, 2019
Do you have "Flash off" selected in menu? Also, if in manual modes, will not come up automatically. Try auto.
Nikon COOLPIX... | Answered on Jun 15, 2018
This camera does not have Manual Function. Your description sounds like the camera is OFF or needs to be RECHARGED. It seems dead to me - no power.
Nikon COOLPIX... | Answered on Dec 24, 2017
Yes - when editing images, always copy them to your computer and do it there. Do not copy the images back to the card, as the camera will be unable to read them - as you have discovered.
Nikon COOLPIX... | Answered on Nov 20, 2017
While a cable is connected to many Nikon cameras the screen shuts down.
Nikon COOLPIX... | Answered on Nov 11, 2017
before clicking any pic. format the card first.
Nikon COOLPIX... | Answered on Aug 24, 2017
Is this a card that has worked before and now doesn't? Do other card(s) work in the unit? If a card is attempted to be installed backward, it can damage the internal connections and make the card slot inoperative. Also, there are restrictions on the type, size, and speed of cards that can be used (identified) within the device. Here is a link to the manual; check page 20 of the technical notes and index (page 230 of the pdf).
http://cdn-10.nikon-cdn.com/pdf/manuals/coolpix/L820RM_EN.pdf
Nikon COOLPIX... | Answered on Jun 02, 2017
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
Nikon COOLPIX... | Answered on May 14, 2017
You can download manuals at NIKONUSA.com
Nikon COOLPIX... | Answered on Apr 15, 2017
Nikon COOLPIX L101 Digital Camera Logo
Popular Tags
4 questions posted
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
camera in sea water damage mainboard
  • Cameras
