20 Most Recent Nikon COOLPIX L4 Digital Camera Questions & Answers
Turn nikon coolpix L26 into webcam
Not possible. Buy webcam. Cheap enough.
12/5/2017 12:49:12 PM • Nikon COOLPIX L4... • Answered on Dec 05, 2017
Lens cleaning
Your camera is with fixed type of lens. Hence self cleaning lenses is not advisable. Contact camera technician will save your camera.
10/1/2017 2:36:33 PM • Nikon COOLPIX L4... • Answered on Oct 01, 2017
Regarding starting on the camera
This camera is now ten years old, and will only take an SD card, with a max limit of 2GB. It cannot recognise or use a more modern SDHC card, which is what I suspect you have been trying to use.
9/23/2017 9:24:05 AM • Nikon COOLPIX L4... • Answered on Sep 23, 2017
Camera left in a damp car.Shutter comes out but no picture for taking a photo.
If there is a "DISP" button on the back of the camera, press it. Also, make sure you have fully charged batteries in it.
1/7/2016 1:04:47 AM • Nikon COOLPIX L4... • Answered on Jan 07, 2016
My camera won't flash.
You can force the flash to off. on page 18 of the manual. You can see if the flash will fire while pressing the shutter release button. If this does not help, remove the battery for a few moments and replace it. If the error keeps coming back, after you did change the settings to flash on, contact a Nikon service centre close by. 444c5307-866b-44e9-ad27-78e8ae7c54f9.png ce404193-2ec7-419b-a80b-b481e8fe754f.png
7/11/2014 12:20:34 PM • Nikon COOLPIX L4... • Answered on Jul 11, 2014
Why do the batteries die fast
They dont if you have quality batteries
6/3/2014 6:07:27 PM • Nikon COOLPIX L4... • Answered on Jun 03, 2014
Why do the batteries die so fast?
You are using AA batteries get the best batteries dont use cheap I can shoot 12 hours before changing
6/3/2014 6:06:15 PM • Nikon COOLPIX L4... • Answered on Jun 03, 2014
Why do the batteries die so fast ?
because its a power-hungry beast..... i would make it a battery pack modification and just use it as a in-car recorder for insurance purposes.
5/25/2014 5:12:51 AM • Nikon COOLPIX L4... • Answered on May 25, 2014
My camera kepts saying file contains no image
try to FORMAT the memory card using your camera. it will solve the problem, o try to use a different memory card with diffrent size, or Higher speed
2/14/2014 2:52:26 AM • Nikon COOLPIX L4... • Answered on Feb 14, 2014
Broken screen 20.1 mp s3400
Contact a Nikon certified service centre and ask what the replacement of the screen cost. Then look what a new camera costs and decide. If you still can make pictures, but you can't see the results, go on shooting and try to live wit the broken screen. Take care from a broken screen sometimes dangerous fluids can leak out. Don't touch the chemicals, wipe them off with a paper towel.
2/13/2014 4:18:23 PM • Nikon COOLPIX L4... • Answered on Feb 13, 2014
File contains no image data
If you format, you will lose everything...format means erase and optimize. Take your card to a store like Walmart that has a Kodak picture maker machine. It will usually read all the pics on a card and you can make a cd of them on the machine.
2/13/2014 10:39:39 AM • Nikon COOLPIX L4... • Answered on Feb 13, 2014
Camera works great but flash wont work on any
Maybe the bulb needs replacing? Try Googling or take it into a camera shop and ask if the bulbs can easily be replaced.
9/22/2013 12:41:15 PM • Nikon COOLPIX L4... • Answered on Sep 22, 2013
Format memory card how do format the memory card
Use the Format command in the Setup menu. See page 63 of the manual: http://www.nikonusa.com/pdf/manuals/coolpix/L4_en.pdf
6/24/2013 3:00:18 PM • Nikon COOLPIX L4... • Answered on Jun 24, 2013
Format memory card
6/24/2013 2:59:51 PM • Nikon COOLPIX L4... • Answered on Jun 24, 2013
3answers
Nikon Coolpix L4 flash not working
This has happened to mine a couple of times. I cannot select flash, and the blur indicator is on most of the time.
Solution is to go into 'menu', select 'SET UP' then 'reset all'. My flash selection then works again.
Since one doesn't tend to set much up with a basic camera like this, resetting shouldn't cause any issues.
Hope this helps
4/10/2013 3:20:57 AM • Nikon COOLPIX L4... • Answered on Apr 10, 2013
Card cannot be used error message.
If you cannot find a solution to your problem you may want to email [email protected]. He has good advice and good used parts at a fair price.
2/1/2013 11:56:59 PM • Nikon COOLPIX L4... • Answered on Feb 01, 2013
3answers
Memory card malfunction
Pictures can sometimes be recovered by sending the card to a service provider, or by downloading software designed to recover the pictures from the card. It is not clear weather the problem is the card or the camera, however to recover the pictures from the card would be the same process. If you do not have one you will need to buy a USB card reader to load the card on the computer. Consider buying another card to test in the camera, if you so wish. If the camera is new enough also consider contacting the manufacturer for warranty assistance. David Millier Advance Camera Repair
10/15/2012 7:40:01 AM • Nikon COOLPIX L4... • Answered on Oct 15, 2012
Nikon COOLPIX L4 Digital Camera Logo
239 questions posted
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
broken screen 20 1 mp s3400
  • Cameras
