Two things to try. Either unplug it or turn it off at the breaker.. Clean the cook top control area and allow it to dry overnight. You can turn the power back on after cleaning ideally. In the morning, with the power resumed just wipe the control area off with your bare clean hand.
I have no idea why this worked for me, but it did. Good luck.
If that fails, you can look up error codes or schedule a repair.
SOURCE: need help to unlock the cooktop
You will have to hold the lock button down for 3 or 5 seconds for it to unlock. If this doesn't help, it could be a stuck key pad or a problem in the circuit board.
Thanks/Mike
SOURCE: Kenmore 44083 Cooktop
should be an unlock button.....press and hold the button until it unlocks
SOURCE: Cooktop shut off and lock itself up
36" electric wolf brand cooktop. Goes off completely after just few seconds sometimes 30 sec. sometimes minute..Repair man looked at it-thinks either something electrical or some sensor messed up.He took apart look at electric ribbon nothing looked over puts back together..turns on and it goes completely blank again..no error codes..any suggestions
SOURCE: The cooktop has locked me
I'm fairly certain all you need to do is press down where the illuminated red key is for about 5 seconds. If this doesn't work, please let me know and I will check on the correct method for this exact model.
Regards,
BElectric
Testimonial: "Thanks for that, I tried it and it worked"
Does it have a child safety lock?
Testimonial: "no it does not........"
