20 Most Recent KitchenAid 32 in. KECC508 Electric Cooktop Questions & Answers
0answers
Clipped and now cracking ceramic
Sorry to read about your problem, I hope this helps you out.
you may want to think about a new unit, the glass replacement will cost from $600.00 to $900.000
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
12/21/2010 3:27:20 PM • KitchenAid 32... • Answered on Dec 21, 2010
The stove top of my
keep your finger on the unlock button for about 10 sec.
please rate this response, with the thumbs up selection
12/19/2010 6:52:54 PM • KitchenAid 32... • Answered on Dec 19, 2010
Can't turn on KECC508 cooktop
The middle light is the lock. You must hold it down for at least 7 seconds to unlock it, then the middle light will go off. Your hands can't be wet, or none of the buttons on mine work right.
10/13/2010 12:42:36 AM • KitchenAid 32... • Answered on Oct 13, 2010
2answers
Stove top will not turn on - touch control
I have a Kenmore and it did that. I kept the lockout button pushed in until it beeped
9/5/2010 2:56:02 AM • KitchenAid 32... • Answered on Sep 05, 2010
Electric igniter does not work every time
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
8/18/2010 9:55:38 PM • KitchenAid 32... • Answered on Aug 18, 2010
How to unlock
May I get the make and model # so I may help you more
8/4/2010 4:37:53 AM • KitchenAid 32... • Answered on Aug 04, 2010
We need the glass top surface replacement and
You can order the glass top on the links below. The first one is black and tha sewconed one is white.
http://www.appliancepartspros.com/part_details.aspx?part_id=3047008
http://www.appliancepartspros.com/part_details.aspx?part_id=3047009
The manual on the link below.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203191524.pdf
If that is not your cook top go to this link below to find the right one.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=KECC508
Good Luck.
5/25/2010 3:44:33 AM • KitchenAid 32... • Answered on May 25, 2010
Burnt on stains on the inside glass door of my kitchenaid oven
DeBruce Polish should remove those types of problems and also render the surface more "Cleanable". This stuff really works on glass anomalies.
Check out debrucepolish.com.
DEBRUCE METHOD on You Tube
4/21/2009 1:19:14 AM • KitchenAid 32... • Answered on Apr 21, 2009
I need tips on cleaning
Use DeBruce Polish. debrucepolish.com. a "True Multi-Surface Cleaner. I guarantee it!!
2/10/2009 7:22:23 PM • KitchenAid 32... • Answered on Feb 10, 2009
What electric voltage plug do I use for KitchenAid 32" cooktop
I would use the 220volt 60amp available at any hardware store. Just make sure you check the wall outlet you are going to use. The Dryer and Range are not the same.
11/7/2008 4:48:33 AM • KitchenAid 32... • Answered on Nov 07, 2008
Our cooktop will not turn on!!
Plug the power line press the reset button.
6/16/2008 1:12:24 PM • KitchenAid 32... • Answered on Jun 16, 2008
My Kitchen aid cooktop model number KECC667BBL won't turn on
Mis-wired or the new control panel is faulty. Call them back, it is under repair warranty. The parts aren't cheap! https://www.searspartsdirect.com/model/41v4g0ja62-000593/kitchenaid-kecc667bbl01-electric-cooktop-parts ..
2/9/2022 7:12:27 PM • KitchenAid... • Answered on Feb 09, 2022
KitchenAid 32 in. KECC508 Electric Cooktop Logo
23 questions posted
Top KitchenAid Cooktops Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
View Most Popular
KitchenAid Cooktops
  • KitchenAid Cooktops
Most Popular Question
stove top
  • Cooktops
