Could be the salt level is low. check the tank in bottom of the dishwasher inside.
Testimonial: "It's a dishwasher, not a water softener."
dish washers have a salt tank in the bottom tank,
SOURCE: oe code on LG dishwasher following garbage disposal replacement
Well, there is the plastic block in the garbage disposal where the drain hose goes on (as not every disposal will be attached to a dishwasher). Punch this out with a screwdriver, fish the plastic plug out with your hand and reattach the hose. You are good to go.
SOURCE: LG DISHWASHER LD-12AW2
ae unknown code,,,but ie that means uinit is taking to long to fill,,your inlet screens are clogged or the water pressure is to low...kinked hose...onthejob
SOURCE: My LG dishwasher stops running 5 mins in
The LE code means there is a problem with the washer motor. ( Motor error ) Condition : The motor is working abnormally. Possible cause : Wiring connections. The impeller of washing pump is locked. The rotor of washing motor is locked. The blade is locked.
Remedy: Correct wiring connections. Replace the cause of restriction. Replace the washing motor. Replace the PCB.
SOURCE: dishwasher quits running and clean lite keeps flashing
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
