Detergent leaking out of nut into bottom pan and causing an e:15 error code.
SOURCE: leaking detergent
Sounds like the back of the soap drawer or inlet hose is partially blocked. Check whether junior has posted a toy car in the drawer
SOURCE: Washer Leaks from Detergent Compartment
Two things might be wrong with this unit. One problem is there is a blockage inside the hose that sends water into drum. Make sure that's clear. The other problem is the dispenser assembly may have a leaking problem and will spray water at an angle that will cause it to leak through the dispenser drawer. My recommendation is to have the dispenser assembly inspected and possibly replaced.
SOURCE: WhirlPool Front Load Washer Leaking
to richhardh..
did u try holding the "End of Cycle Signal" button for 3 ?
SOURCE: BOSCH WASHER REPLACEMENT PART
I have the same problem. Bosch no longer stocks the replacement for my particular washer which has the same model no but could be a different fd #. I now have the wrong part as directed by bosch which doesnt have the hose connection. I am not sure what to do with the hose leading to nowhere. Bosch is living off of an undeserved good reputation.
In the present, the reputation is not deserved. Bosch products should only be recommended to enemies. The company and the especially the customer service is beyond deplorable. I hate these appliances. I feel ripped off! The part by the way, which is wrong, is 100.00 with tax.
SOURCE: kenmore elite he3
ck for blockage between dispenser and where it comes into tub just above door have known dry detergent if used not disolve and cake up blocking inlet to tub also be sure drawer is clean and ck above drawer in washer and clean small holes
