20 Most Recent
Bosch 24 in. SHX46A05UC Built-In Dishwasher Questions & Answers
I have a Bosch SHX46A05UC/33 5-cycle dishwasher
Some SHX46A washers have 4 cycles and others have 5 cycles.
I'm fairly sure your model has the hidden buttons on the top of the door and you stated you have five-cycle buttons, in which case they will be as follows.
1. Top Rack only cycle or Sanitize
2. Power Scrub Plus
3. Regular Wash
4. Delicate Wash
5. Rinse and Hold.
These buttons are also used for cancelling a wash cycle. Hold down "Power Scrub Plus" and "Delicate" at the same time to cancel a cycle and drain the water out.
If your washer does have 4 buttons, it means you don't have a Top Rack / Sanitize cycle, in which case the button configuration (from left to right) will be:
1. Power Scrub Plus
2. Regular Wash
3. Delicate Wash
4. Rinse and Hold.
I hope this solves your problem. If you need any additional information, please post back.
Regards,
BElectric
Bosch Model shx46a05Uc/14 not running
Unlikely to be a level problem. Remove the filter and two screws holding the cover over the wash motor impeller from inside the wash tank - check for something jamming the impeller, like bits of broken glass or fragments of bone, fruit pips etc.
If not that, check basics - water supply, drain hose, filters clear, not syphoning empty, etc.
Wash cycle stopped with water
Check the wiring in the units junction box. Its located at the bottom right corner. You will likely find melted connectors. If so, you need to cut the wires back and replace these connectors. Make sure you turn the power off before doing any of this work of course.
Good Luck.
Smelly dishwasher and slow cycle
The fact your machine gives off an odour and a slow cycle seems to point to a blocked pump, Disconnect the machine from the main power supply, Remove the back and you will find the pump located at the bottom of the machine, Remove the large hose by squeezing together the retaining clip and you should find it is clogged. Clean all filters within the machine and it should clear the odour and help the machine to run better.
When troubleshooting my shx46a05uc bocsh diswasher
sounds like the electronic switch usually a Thyristor is not switching when you push the eco button, You could try disconnecting the the machine from the mains then push the buttong in and out a few times to see if the push button has a bit of dust on the contacts..
