SOURCE: Cuisinart DCC 1150: coffee is not hot enough
Using the 1-4 cup setting will help, but that model does not have an actual heating element in the plate - definitely not the right model for someone who likes very hot coffee.
SOURCE: Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
SOURCE: water drippin from the hot water outlet on a Bunn coffee maker
Hello. If this is the hot water faucet, on the front of the unit, there is a rubber seat that keeps it sealed. Usually it gets a piece of debris, or scale in it with use, or the rubber seat gets worn out and needs replacement. To check, turn off your water, unplug the unit, and drain all the water out of the faucet until it stops, then tilt the unit forward slightly just to get a little more. Now you should be able to unscrew/disassemble the faucet, and pull it out to look at the seat cup, and the faucet interior. If there is scale or debris on the cup, and the faucet interior, it will need to be cleaned, and it may actually require chemicals for scale, if bad enough. If the rubber seat cup is torn, it will need a new one. You can get a new seat at a parts supplier for commercial units in your local area, look in the phone book under "restaurant equipment repair" or go online, plenty of them have a web site. If it is NOT your faucet dripping, we can go from there.
Hope that helps, and thank you.
SOURCE: water leaks out from underneath coffee maker
Well they don;t give these away for sure. Lets see if we can help you out. ? are you over filling it.This happened to me because I was reading the fill line wrong. {got new glasses} . If not may be you could try makeing less. But if only 1/2 cup comes out and no more, that wouldent indacate a leak in the tank, if there was it would all leak. Try backing off on the coffie and water, and see if it still leaks. if it does get back to me. DFD
SOURCE: Bloomfield 8571 Coffee Maker Problem
are yu cleaning it regularly? Scale build up in the tank will cause the heater to become less effective and the thermostat to read the water temperature incorrectly
