Maximum capacity for nikon D50 is 2gb, try use lower capacity, if error still appears, bring it to your local service center, possibility of hardware problem
The camera is really outdated. I think that you just need an upgrade. Look at D5600 for example which is much better and costs not that much. Here is a Nikon D5600 lenses buying guide which also may be useful. I understand that you don't really want to waste money while you have a good camera already but it's like using an iPhone 3 in 2019.
SOURCE: Nikon Coolpix P4 - no power after little piece between battery and SD card ...
the little white peice is what holds ur battery cover closed i think, so without a closed cover it cant really function. i think so anyway
SOURCE: "this memory card cannot be used" message appears
Get a card reader and download the pics to a computer. When they are safe, format the card in the camera to get it to work properly again.
SOURCE: Nikon d40xcamera...sd card won't click into slot
there is a lock on the side of some sd cards try checking if there is one.
SOURCE: nikon d3100 showing no sd card inserted message even after inserting it..please help
The only thing I can think of remove the SD Card, start camera, and go into the menu, check to make sure there are no pictures on the internal memory, if there are! erase them and restart camera and power off, re-install card and hopefully you are good to go. If no change! have the camera shop run a quick check.
