SOURCE: will not spray
The heater is probally clogged. Remove the upper housing and locate a rectagular shaped object in the middle of machine. Remove six bottom screws and clean with stiff brush, clear all lines then run 3 tanks of hot water trhought he system to clear it.
SOURCE: Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
SOURCE: Gaggia Coffee Classic Steam Valve Leaking - No Pressure!!
Yes it can be repaired if you have the parts, you will need the complete steam valve with the o-ring that connects to the boiler check the diagram below.
SOURCE: Saeco Odea Go - Hot water leaks from bottom of machine
That's leaking from the hoses coming out from the boiler,if the machine is new it should be still under warranty, may have to take it back to the service center.When making coffee the lines are under pressure and the water never have a chance to pass through the ground coffee.
SOURCE: Gaggia Syncrony logic rapid steam machine leaks water from bottom
Check the chamber under the white plastic valve behind the brew unit, it might be blocked with coffee.
