20 Most Recent
Frigidaire FASE7073LW Affinity 7.0 cu ft Electric Dryer Questions & Answers
Replaced heating element now I get error E61, I ohmed out the thermostat on top of heating element seem to be ok
Hello Louie, I appreciate your inquiry!
Based off the information you have provided your Frigidaire dryer is displaying an error code of "E61" after you have replaced the element. An "E61" error code means that there could be an issue with your heater relay or main control board. You may need to seek additional assistance from a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. I hope this information is helpful to you. -Matt
Fase7073nwo
Good Afternoon Friend, this is Z. Thank you for your question!
An error code E64 is associated with the heater circuit in the open position. A technician would typically check the heater coils and connections for short circuits to the cabinet to determine if this is the cause of the error code. Depending on the readings, the heater and/or wiring will possibly need replacing. This is not a normal DIY job so you may want to connect with a local servicer to determine the exact diagnosis to help reduce the risk of unnecessary parts. I hope this helps explain the error code you are receiving.
I have a Fridgidaire Model LEQ144ZES0. Dryer will run for about a minute, shut off, then the display lights on far right Drying,Cool down,Prees Saver, Clean lint filter flsah 6 times and then thr Star
Good Morning Friend,
I understand that you are having trouble with your Frigidaire dryer, model# LEQ1442ES0, shutting itself off after about a minute. I see that the lights to the far right flash 6 times and then the start and cancel button flash 2 times. This also, only seems to occur when the weather is warm and humid. I suggest putting a dehumidifier near your dryer during the warmer months to see if this helps to draw the humidity away from the dryer. The humidity can cause your appliance to not run as it should. The other suggestion I have, would be to reset your dryer. You will do this by either unplugging it or shutting the power off at your home's circuit breaker for 3-5 minutes. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Have a Frigidaire Affinity dryer giving me a code E51. What does code mean
You are experiencing a motor relay failure. A professional needs to complete the following - If motor runs continuouslywith power applied, check for short circuit across motor relay (RL2), or L1applied to motor relay output (J3-1) with cycle stopped. If motor does notstart when Start key is pressed, check for open circuit between L1 and motorrelay connection (J3-2). If no wiring problems found, replace Main ControlBoard.
How do I put my Frigidaire Dryer FEQ1442ES0 into diagnostic mode?
To put your Frigidaire Dryer FEQ1442ES0 into diagnostic mode, follow these steps:
- Hold down the Select and Cancel buttons at the same time for six seconds. After one buzzer sound, the two keys will be released.
- Press and hold the Select and Cancel keys for six seconds right away. The display will indicate "r 2" when the buzzer sounds once.
Once you've put your dryer in diagnostic mode, you may run the diagnostic test to find any problems. You can consult your dryer's operating instructions booklet if you require any more help.
I hope this is useful.
E61 Error code Frigidaire Affinity dryer?
Good Afternoon Friend, this is Z. Thank you for your post!
If you are receiving an error code E61 on your Frigidaire Affinity dryer, first check if it is a false error code by resetting the power to your appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, it could potentially mean that your dryer is experiencing a failure with the heater relay. This is not a typical DIY job. I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. You can often locate a qualified service provider through the manufacturer website.
Best regards.
