When was the last time you preformed any internal maintenance? All heavy duty cooking/food prep equipment requires mechanical maintenance just like a car or truck as those internal motors are pretty high amperage to be able to perform under heavy loads.
There's usually some kind of access panel or port where you'll add the food grade grease/lubricant for the internals. If you've never performed any kind of maintenance you may have to take it down to the gears and wipe away the old grease/metal shavings before applying the new grease.
SOURCE: overheat after grating cheese, make an awful noise
You are putting too much pressure and overloading (motor) the Mixer. Specially if you run it for long time.
Grating cheese is hard on mixers.
Let it rest and turn it back on, ON LOW and little or no load.
