20 Most Recent Powermatic 2 Electric Cigarette Injector Machine Questions & Answers
Powermatic II Cigarette Machine. How can I adjust blades on it please.
Question edited for clarity. Question moved to model category. Cleaning and maintenance, and you can get spares. https://www.google.com/search?q=powermatic+II+cigarette+machine+adjust+blades .
1/1/2024 4:16:17 AM • Powermatic 2... • Answered on Jan 01, 2024
4answers
HOW TO REPAIR POWERMATIC 2 CIGARETTE MACHINE
the machine came on when u pushed level down the part u put tubes on was not sliding out i took apart need help putting it back together properly
12/24/2023 12:06:12 AM • Powermatic 2... • Answered on Dec 24, 2023
Poweroll 2 Electric Cigarette Machine light flashes a blue light and will not roll a cigarette?
Question edited for clarity and spelling errors. Question moved from Cars and Trucks category. contact the maker direct https://www.google.com/search?q=poweroll+2+Electric+Cigarette+Machine+light+flashes+a+blue+light ..
7/25/2023 3:43:23 AM • Powermatic 2... • Answered on Jul 25, 2023
2answers
Powermatic 111 Plus Cigarette Machine Roller. I need a manual for it please?
Question edited for a lot more clarity. Full 'make mode (what it is)'. 'Manuel' is the name of a Spanish gentleman, a 'manual' is what you need. Advertising information here http://www.powermaticinjector.com/product.aspx?cla=296 Manual is here.
Powermatic 3 Manual
Elektrische Stopfmaschine https://www.stopfmaschineshop.com > upload PDF Plug in and switch on the power. Choose desired density. Lift the lid and fill the tobacco. 4. 5. 6. Powered S. Insert the tube fully into the feeder. 1 page Video
3/25/2023 10:59:58 AM • Powermatic 2... • Answered on Mar 25, 2023
Powermatic 2 Electric Cigarette Injector Machine. I need to replace the tube injector?
Question edited for clarity. Question moved to category. Parts suppliers https://www.google.com/search?q=Powermatic+2+parts ..
3/4/2023 4:48:21 PM • Powermatic 2... • Answered on Mar 04, 2023
My Powermatic Plus Cigarette Roller is moving slow. Not enough torque to get one rolled. What can I do?
Question edited for clarity. Question moved to model category. Clean and lubricate. You can get parts for them. https://www.google.com/search?q=powermatic+plus+cigarette+rolling+slow ..
3/4/2023 4:35:53 PM • Powermatic 2... • Answered on Mar 04, 2023
The injector will not retract
One of 2 things. First is to push the reset button to get it to retract. Then make sure you are not over packing it with tobacco. If all that seems fine, maybe the gear mechanism inside has failed. I know from mine they were known to have plastic gears in the beginning, then were changed to hold up better.
1/13/2022 3:18:44 AM • Powermatic 2... • Answered on Jan 13, 2022
3answers
Jam up
Use a small screwdriver and insert it in the tabbaco outlet to get the tabbaco out. be care full not to overstuff when filling.If you get a lot of jams the tabbaco can be to moist. if so let it dry out a little before inserting. Also the bottom of the bag 'shake' will jam the machine.A nice tabbaco that is very easy on any machine is a virginia blend.
11/16/2021 3:10:15 AM • Powermatic 2... • Answered on Nov 16, 2021
3answers
Tobacco only goes half way down thetube
inspect that the rubber piece that holds the tube.Chance's are that it is worn and needs to be replaced. it wont hold the tube all the way if it is worn. A quick fix is to cut a piece of eraser of a pencil and glue it to the holder.
10/25/2021 2:28:46 PM • Powermatic 2... • Answered on Oct 25, 2021
4answers
Tube will not fill near filter
Trick i have learned is to put a small amount of tobbaco in the chamber now move it side to side with your finger tips. Now add more tobbaco to the chamber as you normaly would.It will fill the tube better If that does not work out for you try virginia blend tobbaco it will work better in any machine...
10/20/2021 8:56:24 PM • Powermatic 2... • Answered on Oct 20, 2021
How do you replace rubber pads on tube holder?
you need a rubber bumper call them google it
7/15/2021 11:31:55 PM • Powermatic 2... • Answered on Jul 15, 2021
3answers
Were can i find replacment parts in utah for the powermatic 2 electric cigarette machine
Type that question just like you said it in the search engine address bar and hit enter. You will probably see matches. I’m happy to help further over the phone at https://www.6ya.com/expert/tami_f8d2d553d5094045
7/17/2019 9:27:38 PM • Powermatic 2... • Answered on Jul 17, 2019
5answers
Cigarette tube tears at end
This is some what normal.
7/11/2019 4:38:44 PM • Powermatic 2... • Answered on Jul 11, 2019
The machine got jammed and I heard it snap so I know it broke. this is the 2nd machine I have bought in 2yrs. I try not to put too much tobacco in there but it snapped. How can this be repaired?
you are loading way too tightly, do not force when pushing the handle down, if you have too you are over packing. I have loaded 200 cartons of cigs on these machines and never broken a thing
1/15/2019 10:02:45 PM • Powermatic 2... • Answered on Jan 15, 2019
2answers
Plastic end on injector broke where can you buy parts Power Matic II ?
I called them or pic your part here then call http://www.powermaticinjector.com/c2instruct.asp
1/15/2019 10:55:21 AM • Powermatic 2... • Answered on Jan 15, 2019
Can I buy a power cord for a Powematic 2 cigarette machine ?
If you have a laptop cord thats 2 piece you can use the first part of the cord to run your machine just tried it and it works.
7/21/2018 8:58:41 AM • Powermatic 2... • Answered on Jul 21, 2018
2answers
Why cant i get a decent cigarette out of my powermate II mach.
I am going to go under the assumption you are using 100mm tubes. I just switched to kings to make life easier but here is how I filled my 100mm to the filter with good compaction and a trick to get it to the filter. I tightly pack the tobacco against the left side, sticking my finger in the chamber and pushing pretty hard to compact to the left side, I then just do a light poke for the rest of the compartment. Here is the trick part, take a finger and put light pressure pushing on the filter towards the machine, but not so hard it bends the tube and also no so hard that when the injector probe comes out it pushes your finger away from the machine. Using this method I would get around 9 good packs with one redo out of 10 injections. The key is to have enough pressure to hold the filter at the point where the plastic tab usually pushes out and then let the probe push your finger away from the machine. Only very light pressure is needed to make the difference. If the cigarettes are not packing tight you are not compacting enough tobacco in the chamber. There is a fine line though, you need to find the balance as stuffing too much in will cause it to bind up, you just need to find the balance. Once you figure it out it will go very quick, I stuff mine while on the phone and can do around a pack every 2 to 3 minutes or so and get a cigarette that can not be distinguished from a store bought one.Another tip: I use old cigarette packs as containers for my DIY smokes, you can do the same here with a plastic case. If I do get some that are not fully pushed against the filter using the above method, or if the pack just seems a little loos I put them aside and at the end I load them all in cigarette packs just like they come from the store, filter up (otherwise I have a habit of smoking filters from years of them being positioned this way!) and once the pack is full (add good ones if there is space for them to move around, it will not hurt them) turn the pack upside down so the lid is on the bottom. Now tap them firmly about 10 to 20 times against a hard flat surface. This will move the tobacco towards the filter if there is a space or pack loose cigarettes. Warning: From my experience :) Do not over stuff the machine or using the compacting method do not over pack the tobacco, find a good medium. If you over pack the smokes will be solid and very hard to drag from. Do not smoke cigarettes that are hard to rag from, the extra force needed by your lungs followed by introducing smoke into your lungs will result in pain and maybe worse, but I only made that mistake once.Good luck!
1/9/2018 9:12:26 PM • Powermatic 2... • Answered on Jan 09, 2018
2answers
I need a diagram of the components inside my powermatic 2 roller and where each component goes?
Google "photo's of powermatic II cigarette machine " This should bring up a myriad of all images google has of this machine . There is a You tube video Although it is grainy and doesn't show everything . There is no PDF that I could find . The machine shares a name with a famous wood working machine brand . And that is the only PDF user manuals out there .
1/3/2017 12:48:03 PM • Powermatic 2... • Answered on Jan 03, 2017
2answers
The injector shaft will not push the tobacco into the tube, it seems to be jammed, how can I fix this?
that is typically a moisture level issue or too much tobacco loaded. clean it out, use the tools provided or a thin rod to clear the tube, inspect and retry.
11/18/2016 5:57:03 PM • Powermatic 2... • Answered on Nov 18, 2016
Powermatic 2 Electric Cigarette Injector Machine Logo
32 questions posted
Top Powermatic Cooking Experts
ADMIN Andrew
ADMIN Andrew
Billie Aukuso
Are you a Powermatic Cooking Expert? Answer questions, earn points and help others
View Most Popular
Powermatic Cooking
  • Powermatic Cooking
Most Popular Question
repair powermatic 2 cigarette machine
  • Cooking
