SOURCE: Kenmore Serios 80 Gas Dryer - Replacing Gas Valve Coils
I haven't done coils in a while, You will need to remove the top and front panel to access the coils. The top should have catches that allow you to grasp the top by the back corners and pull forward slightly releasing the catch for left an right sides, other will have to have the top console removed to reveal 3 hex screw to pull the top off. Once done get a 5/16 and remove two hex screws left and right on the inside edges holding the front on, also unplug the harness to the door switch, by now the machine should be unplugged. the coils have a flange over them held on by some phillip screws. the orifice is preset so dont mess with adjustments, they should pop out and pop in
SOURCE: Gas Dryer quit heating today
Just click below;
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Hope it may help you;
Regards;
VOTIT
SOURCE: how do i get access to gas valve coils on maytag neptune series dryer
Here is a link of an exploded view of a dryer hopefully this can help you! have a good day! Ps don't forget to give me a rating if this was helpful!!! thank you
http://www.repairclinic.com/0100_17.asp
SOURCE: Kenmore gas dryer no heat
The thermal fuse is easy to test. Just check continuity using a multimeter or ohmmeter. A lack of continuity means a blown thermal fuse.
The coils are difficult to test. You can use a multimeter or ohmmeter and check for continuity, but the problem is that a coil may be sticking open only after heating up, so you can see the difficulty this would present. If a coil is suspected of being faulty, it is best to replace both (all) at the same time. These coils are what permit the gas valves to open and they can cause a no light or a cycling condition. Really sorry for your trouble and I hope this helped. Best wishes.
SOURCE: replacing coils on a dryer
Their are 2 screws to remove and the cover comes off and then those coild simply slip off, unplug em no wiring to do. Thats the cover to the left and the 2 screws.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
