20 Most Recent
Asko TL751 Electric Dryer Questions & Answers
ASKO TL751 error messages ?
Asko dryers as model T760 or T780 indicate failure by error message (like "Overflow", "Sensor", "Thermistor", ...) while the model TL751 indicate failure by error code ("H1", "H2", ...)
Below you can see a list of error codes:
H1 error - Humidity sensor error
H2 error - Drying temperature sensor open/short error
H5 error - Heater overheated (ELECTRIC TYPE)
Heater disconnection check and H4/H6 error (ELECTRIC TYPE)
H3 Error - Flame Detector Open Defect (Gas Type)
H7 Error - Gas Valve Defect or Gas Blocked-off (Gas Type)
H8 Error - Igniter Defect or Flame Detector Short (Gas Type)
Dado
Can I get a list of error messages for an ASKO TL751 clothes dryer?
I googled: Asko TL751 Electric Dryer Error code HI
You may find a manual in this search that gives you the code
If I had to guess it means the high heat is not working, or the high
temperature protection has opened to protect the dryer from
self distruction.
Your owner's manual should give the error codes.
No manual? manualslib.com may have it. YOu may want it next time anyway.
