Solution for No GPS Signal
To pinpoint your location, you
need to get signals from at least 4 satellites. If you receive signals
from less than 4 satellites or the signals are not strong enough, the
Driving View stays gray and one of the following messages is shown in
the bottom right corner of the Driving View:
- Waiting for a valid GPS signal
- The GPS signal was lost sec ago
Note: In previous versions of the TomTom application the message may
vary.
If you see any of these messages, try the following:
Finding a GPS signal
In the following cases it can take up to 5 minutes to find
your current position:
- You use your TomTom device for the first time.
- You haven't used your TomTom device for a longer time.
- Your TomTom device has been relocated without using it (e.g. after
traveling by plane or train).
If it takes longer than 5 minutes, make sure that you are in an open
place without tall buildings or trees around you.
Once your TomTom device has located your current position, the
Driving View is shown in full color and shows your position on the map.
Tip: Most TomTom devices can use
QuickGPSfix™ to locate your current position faster.
Flight mode
On devices with built-in GPRS connectivity, flight mode
also disables your device’s GPS reception.
To switch flight mode off, tap
Flight mode in the
preferences menu and then select
Restore connections.
Clear View
Your TomTom device must be outdoors to locate your current
position.
Try repositioning your device in your car; ideally, try to position
it at the lowest possible point directly on the windscreen.
Some vehicles have a heat reflective shield embedded in the
windscreen, which may prevent your device from locating your current
position. If this is the case in your vehicle, use the TomTom External
Antenna Kit (available as an
accessory).
Tip: As a reference, place your device outside your
parked car to see if it can find your current position.
Reset your device
Reset your TomTom device.
Click here to
learn how to reset your device.
Install the latest application
We recommend always having the latest version of our
application installed on your device.
See also:
How to check for and
install an updated version of the TomTom application?
