Unfortunately, it not a board problem. The LEDs in the TV are bad. These are nearly impossible for repair. As a servicer for television I have repaired many of these. As they were are under warranty, replacement panel is needed for this repair. To purchase a pane,l is not cost effective. What is the panel ? In the old TV, you know what a picture tube is. Well that picture tube in the TV today is the panel. Thanks for asking, Matt of Martins TV Repair.
SOURCE: VIZIO BLACK SCREEN
That problem is the Ysus board, Sometimes people will replace the Zboard at the same time. If you bought it at costco a couple of years ago you are in luck costco will refund your purchase price, costco has changed the return policy and newer tv's are not refunded, but something to look into
SOURCE: I have a 42'' plasma is it worth fixing it
Definitely worth fixing. You may be able to locate an inverter on the internet. Try ebay first. Have seen the inverter for that set for under $50.00
SOURCE: Vizio VO37LFHDTV10A. The screen is black but I
the backlight inverter might be out
Testimonial: "I will order one and give it a try - THANKS!"
SOURCE: Replacing a Vizio Backlight Inverter
I have a television that did this. The picture went out but it continued to have sound. It was the projector bulb. I ordered from a dealer on ebay, very resonably priced. It came with instructions on how to install it and was a very easy fix.
