20 Most Recent
Vizio VW42LF 42 in. LCD HDTV Questions & Answers
Vizio TV stuck in zoom mode
Does the tv menu or tv remote have a zoom option? It may also be labeled as "aspect ratio" or the like. I suggest trying to find this and pressing the buttons a couple of times until you get a satisfactory image.
Speakers Random Static Sounds
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "
brand name" to your device; in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts.
42" vizio vw42l - no picture or sound
If the backlights for the screen do come on and you also have 12v and 5v feed the main board then it does sound like the mainboard will need to be replaced.
VIZIO tv model VW42LFHDTV10A serial LJPBYBJ1405269 sound good but no picture.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Turns on then off right away
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Vizio tv remote not responding
possibly bad batteries in the transmitter. could also be a blocked IR receiver at the TV(do you have something in front of the IR receiver in the TV?) last resort could be either IR receiver PCB or the MAIN PCB.
How do I diagnose a problem with my TV set?
Hi Gertha
Switch Mode Power Supply.
Either a PCB or a Metal Box. Usually the first place the AC wires go to internally. They fail usually because of Bad Electrolytic Capacitors. Look at the Electrolytic "Tin Can" Caps and see if they Bulge from the top or are leaking on top or bottom,
Replacing these with similar or better values does the trick.
Otherwise replace the whole Power Supply PCB Unit.
Good Luck
