Washing Machines Logo
Richard Bettters Posted on Dec 15, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore HE3T no water
Chris Huff
Level 3:
Top Expert:
  • Washing Mach... Master 6,289 Answers
  • Posted on Dec 25, 2018
Chris Huff
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2020397
Points
74913
Water valve may be bad or screens clogged.
Frank Whitington
Level 2:
Habit-Forming:
New Friend:
  • Expert 72 Answers
Frank Whitington
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
72
Questions
Helped
16591
Points
169
Go to the manufacturer's website and enter your model number and click on "Support" and there should be a FAQ's, Owners Manual or other support options for you. Otherwise the website may have a "Contact" phone number to call or a way to Chat online.
2helpful
Kenmore elite he3t where is the lint trap?
Raise up your washer slightly or feel for 3 screws right under the front, bottom. Unscrew these and pull down - you will find the lint trap. Be prepared for water, and since the model is 2002 - immense junk too!
Pl say so if helped!!
It starts to fill with water than stops to soon and the motor is just running
my Kenmore He3T Stop But Remain have water on the bottom!!!
What happen
Kenmore he3t front load washer doesn't turn on, only two beeps. I've tried unplugging it and same result.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
2answers
Kenmore HE3t Frontloader Fills Up With Water After Cycle
Does this change if you select a cold wash or a hot wash? What's the water temperature feel like when it fills? I'd suspect the water control solenoid for either the hot or cold water isn't shutting off completely. This could possibly be due to a piece of debris or mineral deposit in its seat, and could be cleaned with CLR or citric acid if you remove it. They're not very expensive and not a very hard item to change on most machines.
My he3t washer when water goes in tub it leaks
most liklet to be a split pipe under the mashine lay it onits side and look under it at all the pipes replace the loos or split one
Kenmore elite washing machine spin cycle slow. The clothes are still dripping wet when removed from the washer.
In my HE3T, this was indicative of the water pump going out. In its 8th year, my HE3T is now on its 3rd water pump.
Kenmore he3t door locked cant reset or open
Kenmore HE3t sanitary cycle setting has changed. Water temp selection only allows Hot/Cold selection but should offer the Extra Hot selection. All other settings test out properly. Is there a way to reset factory settings for cycles?
Top Washing Machines Experts
john h
