SOURCE: on cloudy days buzzer,speakers will not work. if sun shines will
Sounds like speakers are going bad. I had a set that got wet and they worked sometimes, didn't work other times. Sounds like the bigger issue is why they're getting wet. I'd check to see if rain, etc. is getting down into the door somehow.
SOURCE: AMBIENT 5 DAY FORECASTER
If the product appears to work, then it's most likely it's simply broken. Something responsible for lighting up the day L.C.D. isn't connecting or is shorted out. Take your receipt to place of purchase for a new one. Not many pros can fix just the Day part of LCD displays; the expense outweighs the cost of a new one.
One thing to consider is these types of LCD read-outs are sensitive to water. Did you get it wet, or place it in a very steamy room (shower, clothes drier) ?
That would explain the problem but my advise is still the same. If receipt is gone, sell it at a Flea Market; caveat emptor (Latin for marketplace law, "Let the Buyer beware" - you needn't necessarily tell anyone the Day is broken and you can use the proceeds towards a new one, lol!
SOURCE: The weather Forecast Icons don't change on my
This problem could arise due to various reasons
1)Replace the batteries in remote sensors
When the batteries are properly installed, the remote weather sensor will resume sending signals to the main unit.To enforce an immediate remote signals search, press and hold
DOWN on the main unit.
2)Remote thermo-hygrometer sensor could be weak in sending the signal about weather Forecast.Test it properly.
3)Reset the unit and check
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
SOURCE: Midland Weather Radio Will not give a weather report
Have you gone into the setup mode and adjusted the voulme setting?
Just a thought. The volume may be turned down too low.
