SOURCE: Terrible scraping noise from drum,what is it?
more likely there is a bra wire caught between the inner drum and outer tub, possibly wrapping itself around the element in the bottom.
SOURCE: Bosch Maxx WFL 2260
thanks sorry i have no hands on experence with bosch as im in usa and dont have many in my neck of the woods but there are bosch experts in here
SOURCE: Bosch Maxx WFL 2260 not draining - nothing in filter - help?!
sounds like a simularproblem i had, a 5cent piece got caught in the drain solenoid (just between the drum and solenoid) , i had to lift up the front and spin the drain pump fan, on empty, then disassemble and clean pump assy and remove 5cent piece, hope this helps.
SOURCE: washing machine i not draining out. bosch maxx
two possible reasons that you dont drain pump is blocked or to much soap,
SOURCE: Wfl 2260 5 years old The drum does not turn the
if you can here the motor running have you checked the drive belt is still fitted to the drum,,,they fall off at times or wors still they brake,,,
