Google your TVs model number for the owners manual. In the manual, usually near the last pages, there should be a list of codes. If your remote is a different brand from the TV, then a user manual found online should list possible codes as well. You have to try each code independently to find the correct one for your unit.
SOURCE: code button
SOURCE: code for Vizio tv
I contacted Vizio the other day. They tell me that they use the same generic codes as LG. I have Suddenlink Cable, formerly Charter, so I still use the Charter remote. My remote only needed 3 digits and I have noticed that many need 4 or 5. I can tell you that the LG code worked for my tv. I can power on/off, volume, and change the channel. All other functions require the manufacture's remote. The code I used is 005. There was also 004 but that did not work on my tv. Hope this helps someone!
Unfortunately, those remotes only take a 3 digit code. I bought 2 new remotes, which do take 4 digit codes, but the code(s) for the Vizio do not work (or partially). I found that the 4 digit codes for the Goldstar and LG work better than those provided for the Vizio, but still not as good as the original Vizio remote.
SOURCE: cant program Vizio TV using RCA universal remote RCR312W
can i program an rca remote to a vizio tv?
CAN I HAVE A CODE FOR MY FLATVIEW PRECISSION TV
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
OK.
