SOURCE: overlocker janome 304D
The easiest way to remember them is to observe the machine while you turn the handwheel and see. If it rubs put a drop of oil on it.This means on the end of each shaft, on parts which slide; any place which has a friction point. NOT on the knife blades.
sewman7
SOURCE: how do i thread a janome overlocker
there's a good you tube video and threading an overlocker
SOURCE: How do I oil my Janome 664d overlocker
Does your overlocker have a threading diagram on the inside of the front cover? Often this will also show a couple of red dots where you need to oil.
Obviously always best to consult the manual if you have it; I haven't been able to find an image of the threading or oiling diagram for your machine.
If it doesnt have this diagram and you don't have a manual then I would hazard a guess and say that you need to oil the loopers where they move through another metal part. So open up the front and have a look at the lower looper mechanisim, manually turn the flywheel to move the looper and you should be able to see what I mean. The lower looper will move back and forwards through a metal socket piece and the looper bar may look lubricated on each side. So give the metal holding bit a drop and the oil should work into it. There may be a similar looking bit for the top looper, have a look and give it a drop of oil.
Some overlockers will have an oiling point at the back of the sewing table, it may be a little hole marked with red paint.
