I mean, it's probably common for the bad moving companies since I've never faced that kind of mistake from the company. That's why I think you shouldn't skimp on something as important as cross country movers because they're responsible for your belongings and your relocation. I hope that you won't deal with companies like that ever again.
Is that common for moving companies to drop inportant things? Well, now I definitely don't want to hire one.
Really have to ask that anything dropped can be damaged
SOURCE: I GET ERROR CODE 010-349 WHEN TURN PRINTER ON
Hi!
The error issue your printer is facing means "Fuser STS Front Disconnection fail"
First try to reset the printer by powering off and then on. If the problem still persists then you need to detect fuser or fuser assembly which is required to be replaced.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
SOURCE: Problem with OKI ML 395
the lid has 2 small points the holds down 2 censors that indicate when it is off, make sure that there are not broken and that the censors are being engaged.
SOURCE: OKI C3200, status monitor
Check our USB cable. It should contain AWG marking on it. Depending on AWG number there is a limit to USB cable length as follows:
28AWG = 0.81 m
26AWG = 1.31 m
24AWG = 2.08 m
22AWG = 3.33 m
20AWG = 5.00 m
Make sure your cable does not exceed the maximum length according to its marking. Replace the cable if it exceeds the length.
SOURCE: fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
SOURCE: Oki b6200 error code of 006 335
The laser went out. You have to have the ROS replacement kit. I priced it and it was $255 for it. They dont recommend doing it yourself. Its $75 an hr labor.
