20 Most Recent
OKI B4600 Printer Questions & Answers
My B4600 only prints a single copy
You don't say which version of windows you are using. There is no windows 10 driver so you would be picking up a generic driver when plugging in via usb. If windows 7 or 8 then UNINSTALL (not delete) the Universal driver and install the US version 2.2.6. It wont be the printer as printers only print what they get. Its definitely a driver issue.
3/24/2017 8:21:10 PM •
OKI B4600...
Answered
on Mar 24, 2017
B4600 error code 173
The thermal cut-off is defective on the fuser. The fuser assembly will need to be replaced. If your printer is less than a year old you can get it repaired thru OKI DATA.
2/7/2017 1:50:09 PM •
OKI B4600...
Answered
on Feb 07, 2017
Shows an error 173
Error 173 is an upper heater temperature. It usually points to the fuser unit
Power the printer off, make sure the printer is plugged directly into the wall outlet not a surge protector also remove the fuser unit and reseat. If the error 173 message continues, the fuser unit will need to be replaced.
4/12/2016 9:06:28 PM •
OKI B4600...
Answered
on Apr 12, 2016
Error 231 E3
RFID Reader I/F Error An interface error was detected
with the RFID reader device.
01: communication error between
the RFID reader and the engine
PCB.
02: the transceiver circuit error of
the RFID reader.
03: communication error between
the RFID reader and the Tag
chip.
04: the RFID Tag detection error
(more than 4 chips).
11/16/2015 9:13:22 PM •
OKI B4600...
Answered
on Nov 16, 2015
Why Oki b4600 after changing drum devolves toner empty
The toner cartridge is only a supply chamber. The cartridge simply dumps toner into the feed hopper in the drum. When you change the drum the feed hopper is empty and it is likely that the cartridge dropped the last of it supply into the hopper - ergo it is now empty. I recommend shaking the toner back into the cartridge before separating the cartridge from the drum unit when changing them
9/8/2014 9:51:20 PM •
OKI B4600...
Answered
on Sep 08, 2014
