20 Most Recent OKI C5550N Multifunction Printer - Color LED - 32 ppm Mono - 20 ppm Color - 1200 x 600 dpi - Copier Questions & Answers
0answers
2answers
FATAL ERROR 923
923 - black image drum lock error
make sure the black drum is in correctly
make sure black toner is locked
reboot machine
8/1/2012 10:09:54 PM • OKI C5550N... • Answered on Aug 01, 2012
OKI 5550mfp Fax Problems
error 209 - Media Table Download Failure MediaTable Download to PU failed. Reboot.
CU firmware detected an anomaly in behavior in PU (including a violation of communication protocol between CU and PU).
are you suing unusual sized paper?
3/29/2010 4:31:58 PM • OKI C5550N... • Answered on Mar 29, 2010
'928 Fatal Error message' on OKI C5550MFP
928 - fuser motor lock error
take out fuser and check for paper stuck on roller
make sure roller can move
if roller is stuck or damaged, repalce fuser unit
3/29/2010 4:27:55 PM • OKI C5550N... • Answered on Mar 29, 2010
My Oki C310dn printer prints lines through everything.
You need to do s head clean. This could take 2 or 3 goes but should fix it you will find head clean in the maintenance settings. It eats the ink so only do as you need. let me know how it goes. Regards Craig
2/3/2018 6:52:15 AM • OKI C Office... • Answered on Feb 03, 2018
OKI c6150 with error msg 002-fatal error. please, I need a quick answer. do not have time to scroll through pages of older posts
If you printer has an additional memory card fitted then remove it (powered off of course) and turn on and see what happens. If the fatal error is still there then with the age of the machine (getting on in years) it is better to replace it as the error refers to the cpu in the control board and that's expensive on older machines to replace.
6/21/2016 6:10:50 PM • OKI C Office... • Answered on Jun 21, 2016
2answers
Oki c6100 streaks on the back og a copy
replace 1 fuser unit or 2 transfer belt
11/16/2015 9:41:59 PM • OKI C Office... • Answered on Nov 16, 2015
How to reset fuser life error
the best soloution is to replace the unit with a brand new one as reset fuses are difficult to work with on fuser units but if you search the internet you might be able to find a reset kit from alibaba or amazon
10/27/2015 10:45:37 AM • OKI C Office... • Answered on Oct 27, 2015
OKI C9800 CYAN TONER SENSOR ERROR
remove drum units and clean optical sensors located at the back end of he drum slots and clean corresponding reflective plates on drum units
10/27/2015 10:40:48 AM • OKI C Office... • Answered on Oct 27, 2015
Okidata printer c330dn copies have black smudged edge on the right
your drum cylinder (opc) or dev roller needs to be replaced
10/27/2015 10:38:26 AM • OKI C Office... • Answered on Oct 27, 2015
How to reset drum life on OKI C830
Does not work on OKI C830. Get error message such as toner level error.
9/23/2015 8:07:07 AM • OKI C Office... • Answered on Sep 23, 2015
How to reset drums on oki c5950
Amber's solution worked on an oki c5150 as well as on her 5500. At first, I got into other menus and did not see what she'd described. I cancelled out, then re-ran her procedure following its steps EXACTLY... At the very end, I may have seen one additional message - "EXECUTE" - which I "entered" to launch the process. Printer now works while I find instructions on how to replace "just the drum". The OEM drum assembly is very easy to change but costs about $125. I found (on Universal Ink & Toner) a drum-only replacement for $30, but there was no instruction sheet with it. This solution has allowed me to keep working while I figure out how to install the new drum. Print quality was excellent right up until the manufacturer's internal counter shut printing down. Quality remains excellent after applying the above solution. THANK YOU AMBER Dave
6/27/2015 11:56:45 PM • OKI C Office... • Answered on Jun 27, 2015
Oki c301dn password
aaaaaa
6/6/2015 11:23:30 AM • OKI C Office... • Answered on Jun 06, 2015
OKI C5550N Multifunction Printer - Color LED - 32 ppm Mono - 20 ppm Color - 1200 x 600 dpi - Copier Logo
14 questions posted
Popular Products
Top OKI Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
C OKI
  • C OKI
Most Popular Question
928 fatal error message oki c5550mfp
  • Office Equipment & Supplies
