Don’t power it up without speaker wires, with no homage load you can ruin the amplifiers. Connect everything up again. Make sure all wires are connect and “correctly”. Positive to positive and negative to negative. This sounds like what the receiver was trying to tell you. They have to be connected like that. Otherwise the sound will be really funky
SOURCE: Yamaha htr5730 receiver - turns off
You may have speaker wires touching each other or a short circuit in the wire. "Check SP Wires" means to check your speaker wires.
SOURCE: DVD Player Will Not Turn On
minr froze and wont turn on now either has anyone had any luck fixing this problem?
SOURCE: Check SP wires
if you checked wire carefully in high ohm reading and confirm no internal short circuit.-please follow me:-1-disconnect all speakers cables from receiver and check if it is fine-try to connect your speakers one by one until you find the bad one.if it is still shut down you will have a problem inside receiver itself and needs service center to fix.
-it maybe speaker check it also one by one with good known cable.
SOURCE: My Yamaha HTR-6050 shuts off at random times and says "Check SP Cable"
i think it means speaker cable?
http://www.fixya.com/search/p514076-yamaha_rx_v2700_7_1_channels_receiver/check_sp_cable
SOURCE: problem with sp cable (yamaha)
The speaker cables are the ones that clamp or tighen down on the back of the reciever. All the spkr wires have to have the positive and negative leads correct. Also not aven one little strand of wire can be touching another conductor or you will have this problem. Make sure all leads are correctly ran and hooked up positive to positive and negative to negative from the back of the reciever all the way to the speakers. This should solv your problem.
