20 Most Recent
Yamaha HTR-5760 Receiver Questions & Answers
When i turn on my receiver, it starts up for a
first of all , check all your speaker wiring make sure none are touching acrros(frayed) . if good disconnect 1 speaker at a time and turn on unit . if it stys on you found your problem- a shorted speaker.
If none of these things work, disconnected all speaker aand check with a volt ohm meter( you can get a cheapie at Radio Shack)- acroos each speaker you should have either 4ohms, 6 ohms or 8 ohms, depending on the rating on the back of the speaker. if any read lower, replace speaker.
If all else fails, go to yamaha.com/usa and go to support, call service center for repair listed on site.
hope this helps ! Steve A.
No sound when connecting optical cable from set
Make sure your "Input Select" "Audio" portion of the main menu is set to "Auto" you may have it in analog thus only allowing audio from the front analog input. Also check your digital input select option as well. you may have it assigned to another source input. Go into the main menu of the receiver and you will find all the settings. Hope this helps. If you still have issues, post a comment and I can help you troubleshoot further.
Yamaha rx-v671 usb overload issue
(francais) hello in my issue the probleme was a little resistor r027 it's in this red zone and very ugly. easy to find. a friend was unsolded the resistor and weld a little wire after wash with isopropanole alcool.
the resistor test the tension when we plug usb thing. less the resistor the usb ports don't work. you can buy r027 for 2 euros for 100 pieces.... or 2 euros for 5 10 pieces (funny).
