20 Most Recent Yamaha HTR-5230 Receiver Questions & Answers
I got a Yamaha stereo
75 ohm FM antenna plug for the FM side eBay will have plenty to give you an idea what to look for
7/9/2017 4:36:51 PM • Yamaha HTR-5230... • Answered on Jul 09, 2017
I have a Yamaha HTR 6230, bought in US ( 120V
Buy a transformer that is compatible with local electrical connectors and supports the wattage it draws.
http://www.world-import.com/all-transformers.htm
People take electrical products between the 2 main voltages all the time.
4/7/2011 11:22:13 AM • Yamaha HTR-5230... • Answered on Apr 07, 2011
Yamaha HTR-5230 5.1 Channels Receiver turns off as
To be able to isolate the problem, you gonna need to disconnect the power amp output transistor(pair) one at a time. :)
12/29/2009 6:25:34 AM • Yamaha HTR-5230... • Answered on Dec 29, 2009
My yamaha htr 5230 shuts off everytime i turn the
Check the speker wires could be shorting out to the cabinet. If you still have the problem remove one speaker at a time.
Probably a bad speaker or wires.
11/25/2009 10:39:45 PM • Yamaha HTR-5230... • Answered on Nov 25, 2009
What adapter do i need for my yamaha receiver to
this is the 300 ohm adapter you need from radio shack and just install some small gauge speaker wire to it. or just splice the one that came with your receiver.
http://www.radioshack.com/product/index.jsp?productId=2062054
6/13/2009 6:29:59 PM • Yamaha HTR-5230... • Answered on Jun 13, 2009
What's a good used price for this 5230 + speakers
Hi. that's a really good price but, make sure it is not in protect mode and it actually works. Plug it up and test all channels for complete sound production.
If it passes the sound test and is not in protect mode, its a steal and i would purchase it.
Please rate and god bless:)
4/23/2009 2:24:45 AM • Yamaha HTR-5230... • Answered on Apr 23, 2009
Yamaha htr 5240 receiver, need fm antenna adapter
this is your manual http://www2.yamaha.co.jp/manual/pdf/av/english/re/HTR-5230.pdf
2/27/2009 1:09:49 AM • Yamaha HTR-5230... • Answered on Feb 27, 2009
Yamaha htr5230 hookup
Hi, Your receiver is really the same as my HTR 5240. Same back and front. basically. Go to Retrevo for manual. Shows all the hook ups. I have VCR , DVD, Tape Deck, hooked to mine but can't find the adapter so i can hook up my indoor fm antenna. All my components plug to back of receiver then there is one RCA wire running from receiver to Tv.
2/27/2009 12:15:26 AM • Yamaha HTR-5230... • Answered on Feb 27, 2009
2answers
Subwoofer
i have the same tuner.on the back you will see all connectors bottom row of rca jacks you will see subwoffer if your sub has to rca. red/white use a splitter monstor cable gold ..works best. i use Home Theater Reserch speakers... you can also plug your subs power plug into the tuner snd you never have to power it on seprate .........
3/31/2008 4:59:05 AM • Yamaha HTR-5230... • Answered on Mar 31, 2008
Can I connect my computer subwoofer to my Yamaha A/V receiver
Yes if it has a suitable speaker connection available and is nominally 8 ohms impedance Speaker and AV.
4/15/2024 11:25:42 PM • Yamaha Audio... • Answered 8 hours ago
Yamaha M-60 Power Amplifier distortion and sound goes off sometimes
Being from 1985 or there abouts, it probably needs some TLC at a Yamaha service centre. May need new capacitors and resolder dry joints for age related issues.
4/1/2024 7:26:20 AM • Yamaha Audio... • Answered on Apr 01, 2024
Jerky sound in one channel Yamaha M-60 Power Amplifier
WD-40 ... Very dangerous as it not only flammable when wet but is bad for electrical contacts as it leaves a residue behind that does not conduct electricity very well. Check speaker connections first.
4/1/2024 7:22:45 AM • Yamaha Audio... • Answered on Apr 01, 2024
Yamaha rx-v671 usb overload issue
(francais) hello in my issue the probleme was a little resistor r027 it's in this red zone and very ugly. easy to find. a friend was unsolded the resistor and weld a little wire after wash with isopropanole alcool. the resistor test the tension when we plug usb thing. less the resistor the usb ports don't work. you can buy r027 for 2 euros for 100 pieces.... or 2 euros for 5 10 pieces (funny). ampli r027-w2gpcyn2rttv51s5zcrlhnl2-d-0.png
3/5/2024 10:05:15 PM • Yamaha Audio... • Answered on Mar 05, 2024
RX-V6A - Zone 2 Speakers do not give sound
Follow the procedure as given in following link. RX-V6A ' ENJOYING IN MULTIPLE ROOMS (ZONES) (yamaha.com)
12/14/2023 12:29:06 PM • Yamaha Audio... • Answered on Dec 14, 2023
Yamaha HTR-5230 Receiver Logo
Popular Tags
15 questions posted
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Yamaha Audio Players & Recorders
Most Popular Question
yamaha htr 6230 bought in 120v
  • Audio Players & Recorders
