SOURCE: set correct time on Logitech MX 3200 wireless keyboard
Cordless Desktop MXTM 3200 Laser
To adjust the LCD's time and date:
The time and date on the LCD should now be displayed properly.
SOURCE: logitech wireless keyboard
there should be a little red button underneath the keyboard that aslo has instructions on how to connect
SOURCE: Logitech Wireless CE 0682 Keyboard won't work but mouse does
did this come with software
and you might need to do a uninstall reinstall
if it worked on same pc before it should work now.
if you have a reset button on transmitter try resetting it.
SOURCE: wireless-keyboard-Logitech-s510
Its not the problem with the keyboard or the mouse
it seems that you need the full system scan..
of if you have wired keyboard and mouse connect them to the computer and check using them with the same browsers ... which will determine where the problem is ?
if the wireless keyboard and mouse are working fine
then need to update the drivers
or there is some problem Hack / Virus scan (not sure) but don't worry it could be a magnetic effect of speakers or monitor
you have to check them out
SOURCE: dell wireless interfering with logitech wireless
hi
just go to control pannel , select bluetoth option , paur your dell device with the system you want to work and it will work fine.
