20 Most Recent
Dell Wireless Keyboard Optical Mouse w0147 Questions & Answers
What make the mouse scrolling ?how does it work?
post problems or symptomsnot ask for theses on mouse design.That keyboard is a relic.no history toll, no PC told no OS toldjust a vague scrolling thing.some of those old keyboards use special mouse just for it.and the keyboard most work first. or mouse will be deadall parts that came with the keyboard and mouse kit must not be missing for sure the transceiver USB modulethat keyboard doe now work in w8 ,w10 or w10 OS PCsits too old now.real set name isOEM Dell Computer DELL 310-4170 W0147 MULTIMEDIA WIRELESS OPTICAL KEYBOARD & MOUSE DESKTOP BROWN B Dell Computerzero support exists now.its too old.and kbd and mouse batteries are bad, or rusty train wreck
No red light on mouse...power light on then off again
Wireless mouses never made much sense to me since you have to be right at the computer to use them. I've had so many repair visits when the battery is dead just when you need it most to work. Save yourself the trouble and buy wired mouse.
Dell Wireless Mouse dead
now mouse is open & clean by isoprpile & check battery conector after check now mouse its working.
Keyboard volume control???
Based on years of using computers and seeing many keyboards when I used to do IT work, typically it's not standard for many keyboards to have that, sometimes different keyboards might have an "fn" key though which will allow for other options displayed on keys such as volume up or down. I can suggest a keyboard for you with the media keys if you really need it, anyways I hope you're having a good day, and that I helped somehow.
-Jeremiah
HP K1500 Keyboard
Keyboard not responding
The keyboard has probably died. (It happens often). Here's a great inexpensive combo to replace your current one. https://www.amazon.com/Logitech-MK270-Wireless-Keyboard-Mouse/dp/B00BP5KOPA/ref=sr_1_1?ie=UTF8&qid=1491364851&sr=8-1&keywords=Logitech-MK270-Wireless-Keyboard-Mouse
Dell wireless mouse and keyboard-no instructions
Most Bluetooth keyboards and mice are just Plug-n-Play and does not require any driver installation. You need to isolate the problem, please follow the steps below:
1. Make sure that the wireless adapter of your wireless KB and mouse is properly connected to the USB port of the computer.
2. Make sure that the USB ports of your computer are working.
3. Use fresh batteries for the KB and mouse.
4. After connecting the wireless dongle to the computer, turn on your KB and mouse (there should be an ON/OFF switch underneath).
5. Briefly press the connect button on the wireless dongle and then hold down the connect button underneath the mouse for five seconds and then release it.
6. Do the same steps for the KB.
Have a good day!
My bluetooth mouse used to connect but now it
Mostlikely you need to repair the mouse with the computer. open your bluetooth utility or the keyboard/mouse utility and follow the pairing instructions. this should solve your problem
