As long as the pins are in the same location and correct order then it shouldn't be an issue and if the wattage is the same u should be fine
That's what I was asking do you know if boss andpyle match up
Ok is it for a head unit or an amp or crossover and what wattage. Do uhave the full name ex.dual xdm280 is a head unit i just installed in my car
Ok I'm trying to use the wire harness from a Boss 625CA on my Pyle PLD71MU
Are u sure u got he number right on the boss
SOURCE: wiring harness
I dont think so. 95 had 2 different engines. it will be close. you will have to check every connection and it will take some time. id get the correct one for your model and year and it still might be a little different.
SOURCE: Having trouble installing my Pyle PLDBT30U
your part number is Metra 70-5520
It is a standard Ford plug, but is used on your car as well.
Only 1 plug is necessary
See link - http://cgi.ebay.com/FORD-2003-2007-HARNESS-METRA-70-5520_W0QQitemZ170248469364QQcmdZViewItemQQptZCar_Electronics_Installation?_trksid=p3286.m20.l1116
i dont think this model has a premium sound upgrade.... could it be a changer cable?
SOURCE: i need a wiring harness
I NEED TO FIND A WIRE HARNESS FOR A PYLE IN THE DASH DVD PLAYER PLTSN74
[email protected]
SOURCE: Wire harness for trailer
Hello
i am also having a same issue i get the help from
http://www.rvmechanic.com/current_category.2177/Forum.40676/offset.30/forum_thread_full.html
i think so it is going to helpful for you also
Thanks & Regards
SOURCE: replacement wiring harness for pyle pld5mu
1-888-318-PYLE Ask for tech support they will sell you one.
