20 Most Recent Pyle PLTDN71 Car Video Player Questions & Answers
Pyle PLD70BT wiring to brake
I do believe u ground it or you can also google Pyle bypass codes and totally do away with the whole brake safety option
11/4/2013 5:59:36 AM • Pyle PLTDN71 Car... • Answered on Nov 04, 2013
Remote doesn't work
Check Batteries
12/30/2011 6:18:58 PM • Pyle PLTDN71 Car... • Answered on Dec 30, 2011
0answers
The sreen on my pyle
the slider peice
9/2/2010 10:33:03 PM • Pyle PLTDN71 Car... • Answered on Sep 02, 2010
Hi i installed the car video player, and it works
check that you haven't connected the power wire to the light power make sure its straight from the battery and straight from switchable power
pls rate
8/17/2010 11:30:11 PM • Pyle PLTDN71 Car... • Answered on Aug 17, 2010
I recently bought a PLTS72U power light no functions
check your ground power remote and parking switch
4/15/2010 1:39:27 AM • Pyle PLTDN71 Car... • Answered on Apr 15, 2010
Can some1 please tell me how to connect all the
red-power(keyed), yellow-power(constant), black-ground. If you're having problems installing it, try powering it on with your'e car battery, if that works you have a blown fuse in the system.
9/5/2009 7:42:16 AM • Pyle PLTDN71 Car... • Answered on Sep 05, 2009
Broken wire in wire harness clip
i'm not sure what part is broken from your description but i will try to help...
you can purchase something called a reverse harness that looks identical to your vehicle's OEM harness that plugs into the factory radio. the only difference will be the wiring color on the new harness will be standard aftermarket wiring (ie 12volt yellow, ign red, ground black, etc.) and if you cut each wire from the OEM harness and solder it to the reverse harness location for location then the new harness will be good to go. i would personally do this as a single wire at a time so you are not staring at 16 cut wires going to the new harness. check at Best Buy and see if they carry the 71-1770 Metra wiring harness and that will be the one you need as the reverse harness and if you are installing an aftermarket radio get the 70-1770 also. if you aren't comfortable with all this your local installers should be able to do this job for you pretty reasonably.
8/18/2009 1:49:34 PM • Pyle PLTDN71 Car... • Answered on Aug 18, 2009
I have Pyle PLTDN71, everything is wired properly
u probably connected ur power or constant to ur lights. if ur lights turn on ur accesry switch and than ur ight if ur stereo turns off thanu have tosee witch wire is connected wrong
7/9/2009 6:13:19 AM • Pyle PLTDN71 Car... • Answered on Jul 09, 2009
It was working fine then i changed my car and
bad wiring on the ignition its hooked to the constant and ur brake wire is not properly connected
5/19/2009 12:53:30 PM • Pyle PLTDN71 Car... • Answered on May 19, 2009
2answers
Brake bypass
this is on a website link let me try to find it its a wire buddie had same issuue
12/6/2008 9:49:19 AM • Pyle PLTDN71 Car... • Answered on Dec 06, 2008
WILL NOT TURN OFF!
yes. the probs you bought a pyle. lol. the speakers were good back in the days but the electronics really suck and thus you get prlike you do BUT it seems like your installation technician did something wrong. once you turn your car off the unit should shut off. its probably hooked up to a negative ground or wrong wire.take it elsewhere before your car burns.
12/24/2007 12:11:33 PM • Pyle PLTDN71 Car... • Answered on Dec 24, 2007
Moved out of state , how do I reset old radio preset stations and add new on soundbar
The user instructions explain how to tune it in. https://www.manua.ls/pyle/psbv200bt/manual?p=4
12/29/2023 8:29:47 PM • Pyle Car Audio &... • Answered on Dec 29, 2023
Pyle PLTDN71 Car Video Player Logo
23 questions posted
Top Pyle Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Pyle Car Audio & Video
Most Popular Question
broken wire in wire harness clip
  • Car Audio & Video
