Hello, Anna - What is the make and model of your weather station? I want to help you with your question, but I need more information from you. Can you please add details in the comment box?Hello, Anna - What is the make and model of your weather station? I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
You can't post conmments that contain an email address.
Normally just a matter of replacing the batteries in both units of your MYSTERY Weather Station. My inside one gets low and doesn't record the outside temperature correctly.
There are a couple of possibilities for the failure to transmit/receive outdoor data. First, resynch the two units. This will depend on the manufacturer. For some brands, you need to take the batteries out of both the indoor and outdoor units for 10 minutes. Then put the batteries into the devices with both side by side (working inside is easier). Wait until the outdoor data is displayed. There are some weather station systems where the outdoor unit isn't weather-proof. You may need to dry the outdoor unit for several days after removing the batteries before resynching it to indoor sensor.
If the data displays properly when the outdoor unit is inside, you may have the outdoor sensor too far away from the indoor unit. (The distance will depend on the number of walls and the composition of the wall studs/siding.) Try keeping the two units closer together.
If the outdoor data isn't displayed when the two units are side by side and the reset procedure doesn't work. One device has an internal malfunction (transmitter or receiver failed). It's probably best to replace the unit. If it is under warranty, contact the manufacturer.
I hope this helps. For specific details on resetting the indoor and outdoor units to synch them, please add a comment with the make/model of your weather station.
(I've seen Davis Weather stations damaged by a close lightning strike. The outdoor unit had to be replaced.)
I have experienced the same with numerous different, "quote un quote" atomic clocks! Please don't forget that this sender unit, that goes outside, generates a RF Singal to be received by the clock inside. This unit transmits a signal 433 MHz signal approximately every. 3 minutes, and after so many years the sender unit's RF section(electronics) just goes out or no longer function properly or not at all! The transmitter/sender for this model number, according to "3M" is obsolete and can no longer be furnished, DRATTS !!!!!
